I've been using debian on all my systems for a long time.  On my x86 and x64 systems, debian_version always gets updated after dist-upgrades and upgrades.  It has never been the case for my embedded boards running armbian jessie.  I tried to research into what actually does the trigger, but I can't find any details.
When I log in, my splashscreen confirms there are no new updates (I updated this morning).  It's still showing 8.0 in /etc/debian_version.  I expect to see /etc/debian_version reflect 8.4
Any ideas?
sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... The following packages were automatically installed and are no longer required:
  icedtea-netx-common libavcodec57 libavdevice57 libavfilter6 libavformat57 libavresample3 libavutil55 libchromaprint1 libdirac-encoder0 libflite1 libgme0 libmodplug1 libopencv-core2.3
  libopencv-imgproc2.3 libopenjp2-7 libopenjpeg2 libpgm-5.1-0 libpostproc52 libpostproc54 librtmp0 librubberband2 libshine3 libsnappy1 libsodium13 libsoxr0 libssh-gcrypt-4 libswresample2
  libswscale4 libsystemd-login0 libunique-1.0-0 libva-drm1 libva-x11-1 libva1 libx264-123 libx265-87 libzmq3 ssl-cert
Use 'apt-get autoremove' to remove them.
Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sudo apt-get upgrade
Done
cat /etc/debian_version
8.0
cat /etc/apt/sources.list
deb http://http.debian.net/debianjessie main contrib non-free
deb http://http.debian.net/debianjessie-updates main contrib non-free
deb http://security.debian.orgjessie/updates main contrib non-free
deb http://www.deb-multimedia.orgjessie main non-free
$ dpkg -S /etc/debian_version
base-files: /etc/debian_version
Looks like debian_version gets updated when the package "base-files" is updated.
$ dpkg-query -W -f='${Conffiles}\n' '*' | grep debian_version
 /etc/debian_version 901275afdd9278ae23c429033a63d04e
$ md5sum /etc/debian_version
901275afdd9278ae23c429033a63d04e  /etc/debian_version
At least on my system no other script touched that file.
Thank you, this post was very helpful.
I did a apt-cache show base-files and it showed there were two versions with the on for 8 taking precedence over 8+deb8u7.  So I ran  apt-get install base-files=8+deb8u7
I'll check through and see what other packages this is happening.
