RSS Bot Posted January 29, 2024 Posted January 29, 2024 Description Reworked u-boot compilation for meson-s4t7 to make sure we are following same process for u-boot compilation as Khadas. Now we are not compiling it twice like we were doing it before as mentioned in #6112. Added post install script in uboot with option to force upgrade the same. The code is based on what is being used in armbian-config's bootloader update code. Also moved tinkerboard specific code out to tinkerboards's config How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [X] Tested both vim1s and vim4 boots [X] Tested upgrade with using deb files. I will also test it using beta repository after these changes are merged [X] Checked the postinst script of tinkerboard's u-boot to ensure that the code that I moved is present in postinst script. Checklist: [ ] My code follows the style guidelines of this project [X] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
