asp Posted January 24, 2017 Share Posted January 24, 2017 Hello! I tried to configure built-in wifi module to work as two wifi interfaces at the same time. I had already configured hostapd+dhcpd at the first interface, at the second interface (...iw add interface...) I could scan my home wifi network (wpa2), but I couldn't connect to it (wrong key). I used utilities to connect like wpa_cli, wpa_supplicant, iwconfig, iw. Did anybody done that, I mean is it possible? What i'm doing wrong? Link to comment Share on other sites More sharing options...
jkajolin Posted January 24, 2017 Share Posted January 24, 2017 If you are using wpa_supplicant for the wpa2-type, keymode is actually just wpa. (wpa2 just gives the authentication error). I am evaluating Orange Pi devices for a WIFI AP - nodehub to be used with ESP8266 - devices so I have tinkered between Zero, PC+ and Plus 2E H3 Hello! I tried to configure built-in wifi module to work as two wifi interfaces at the same time. I had already configured hostapd+dhcpd at the first interface, at the second interface (...iw add interface...) I could scan my home wifi network (wpa2), but I couldn't connect to it (wrong key). I used utilities to connect like wpa_cli, wpa_supplicant, iwconfig, iw. Did anybody done that, I mean is it possible? What i'm doing wrong? Link to comment Share on other sites More sharing options...
asp Posted January 24, 2017 Author Share Posted January 24, 2017 If you are using wpa_supplicant for the wpa2-type, keymode is actually just wpa. (wpa2 just gives the authentication error). I am evaluating Orange Pi devices for a WIFI AP - nodehub to be used with ESP8266 - devices so I have tinkered between Zero, PC+ and Plus 2E H3 Thank you for your response. I want to use OPi zero for mqtt+openhab2+wifi_ap_mode for esp8266+same_wifi as client to connect to the internet. If i want to connect to AP which uses WPA2, how i need to configure my connection? What I need use instead wpa_supplicant ? 2. After reboot, OPi zero missing second virtual wifi interface, how to save it? Link to comment Share on other sites More sharing options...
jkajolin Posted January 24, 2017 Share Posted January 24, 2017 Thank you for your response. I want to use OPi zero for mqtt+openhab2+wifi_ap_mode for esp8266+same_wifi as client to connect to the internet. If i want to connect to AP which uses WPA2, how i need to configure my connection? What I need use instead wpa_supplicant ? 2. After reboot, OPi zero missing second virtual wifi interface, how to save it? We don't plan to use Wireless client to connect to the actual outside world, just hostap for the esp8266 to do the RESTAPI posting. How did you create the client / ap separation ? I think basically no matter which you use wpa_supplicant or network manager, you use the interace-name to bind the saved information. /etc/NetworkManager/system-connections for the nmcli and example /etc/wpa_supplicant/ for wpa_supplicant - scripts. I think you can also use nmcli or wpa_cli to do them all manually from a startup service if required. Link to comment Share on other sites More sharing options...
asp Posted January 24, 2017 Author Share Posted January 24, 2017 We don't plan to use Wireless client to connect to the actual outside world, just hostap for the esp8266 to do the RESTAPI posting. How did you create the client / ap separation ? I think basically no matter which you use wpa_supplicant or network manager, you use the interace-name to bind the saved information. /etc/NetworkManager/system-connections for the nmcli and example /etc/wpa_supplicant/ for wpa_supplicant - scripts. I think you can also use nmcli or wpa_cli to do them all manually from a startup service if required. At first i deleted wifi interface using utility iw. Then I create two interfaces: iw phy phy1 interface add wlan0 type __ap iw phy phy1 interface add wlan1 type managed First interface for hostapd - working good. Second interface for connection my Opi Zero to internet. Question is why my second interface didn't want to connect to internet(gome wifi AP), i got always wrong key. home wifi AP working using WPA2. I want to ask, may be someone done the same already. Link to comment Share on other sites More sharing options...
peter12 Posted January 24, 2017 Share Posted January 24, 2017 Hi asp, could you please post exact steps you have done? I plan to do the same with orange pi zero (AP+client). Many thanks. Link to comment Share on other sites More sharing options...
jkajolin Posted January 25, 2017 Share Posted January 25, 2017 I have to try it when have time. If you are using network manager you should create two connection profiles (one client dhcp and one ap static ip) ? If not then create the virtual interfaces to the /etc/network/interfaces file and use wpa_supplication for the client connection(i am not familiar how this is done, only knowledge of bridges on openstack) However as you are also using the eth0 lan connection it may lead into a "arp flux" - scenario if the lan connection and wireless client share the same subnet ? At first i deleted wifi interface using utility iw. Then I create two interfaces: iw phy phy1 interface add wlan0 type __ap iw phy phy1 interface add wlan1 type managed First interface for hostapd - working good. Second interface for connection my Opi Zero to internet. Question is why my second interface didn't want to connect to internet(gome wifi AP), i got always wrong key. home wifi AP working using WPA2. I want to ask, may be someone done the same already. Link to comment Share on other sites More sharing options...
asp Posted January 26, 2017 Author Share Posted January 26, 2017 I have to try it when have time. If you are using network manager you should create two connection profiles (one client dhcp and one ap static ip) ? If not then create the virtual interfaces to the /etc/network/interfaces file and use wpa_supplication for the client connection (i am not familiar how this is done, only knowledge of bridges on openstack) However as you are also using the eth0 lan connection it may lead into a "arp flux" - scenario if the lan connection and wireless client share the same subnet ? It will be great if you try to done this too. Yes, network manager and spa_supplication are on. I note, that if I want to start wifi as AP (hostapd) mode or client mode (wpa_cli utility) on wlan0 - it works. "arp flux" - may be, but it's not a problem, because i can see connection to home_wifi, wifi link is up. The same operations on second wifi interface didn't work (don't matter, ap or client mode). This is some information: Orange PI zero , armbian 5.24 (latest) wpa_cli: Selected interface 'wlan1' Interactive mode <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH > add_network 0 > set_network 0 ssid "Rocks" OK <3>CTRL-EVENT-SCAN-STARTED 1 <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH > set_network 0 psk "********" OK > enable_network 0 OK <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Rocks" auth_failures=1 duration=10 reason=CONN_FAILED <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SCAN-STARTED <3>Reject scan trigger since one is already pending <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SSID-REENABLED id=0 ssid="Rocks" <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Rocks" auth_failures=2 duration=23 reason=CONN_FAILED <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SCAN-STARTED <3>CTRL-EVENT-SCAN-RESULTS <3>WPS-AP-AVAILABLE-AUTH <3>CTRL-EVENT-SSID-REENABLED id=0 ssid="Rocks" <3>SME: Trying to authenticate with e4:8d:8c:e0:de:db (SSID='Rocks' freq=2412 MHz) <3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Rocks" auth_failures=3 duration=46 reason=CONN_FAILED iwconfig: wlan1 IEEE 802.11bgn ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:on wlan0 IEEE 802.11bgn Mode:Master Frequency:2.412 GHz Tx-Power=20 dBm Retry long limit:7 RTS thr:off Fragment thr:off Power Management:on iw list: Wiphy phy1 Band 1: Capabilities: 0x110 HT20 Static SM Power Save RX Greenfield RX STBC 1-stream Max AMSDU length: 3839 bytes No DSSS/CCK HT40 Maximum RX AMPDU length 32767 bytes (exponent: 0x002) Minimum RX AMPDU time spacing: No restriction (0x00) HT TX/RX MCS rate indexes supported: 0-7 Frequencies: * 2412 MHz [1] (20.0 dBm) * 2417 MHz [2] (20.0 dBm) * 2422 MHz [3] (20.0 dBm) * 2427 MHz [4] (20.0 dBm) * 2432 MHz [5] (20.0 dBm) * 2437 MHz [6] (20.0 dBm) * 2442 MHz [7] (20.0 dBm) * 2447 MHz [8] (20.0 dBm) * 2452 MHz [9] (20.0 dBm) * 2457 MHz [10] (20.0 dBm) * 2462 MHz [11] (20.0 dBm) * 2467 MHz [12] (20.0 dBm) (no IR) * 2472 MHz [13] (20.0 dBm) (no IR) * 2484 MHz [14] (20.0 dBm) (no IR) Bitrates (non-HT): * 1.0 Mbps * 2.0 Mbps * 5.5 Mbps * 11.0 Mbps * 6.0 Mbps * 9.0 Mbps * 12.0 Mbps * 18.0 Mbps * 24.0 Mbps * 36.0 Mbps * 48.0 Mbps * 54.0 Mbps max # scan SSIDs: 2 max scan IEs length: 2257 bytes Retry short limit: 7 Retry long limit: 4 Coverage class: 0 (up to 0m) Supported Ciphers: * WEP40 (00-0f-ac:1) * WEP104 (00-0f-ac:5) * TKIP (00-0f-ac:2) * CCMP (00-0f-ac:4) Available Antennas: TX 0 RX 0 Supported interface modes: * IBSS * managed * AP * AP/VLAN * monitor * mesh point * P2P-client * P2P-GO software interface modes (can always be added): * AP/VLAN * monitor valid interface combinations: * #{ managed } <= 2, #{ AP } <= 1, total <= 3, #channels <= 1 * #{ managed } <= 3, total <= 3, #channels <= 1 * #{ managed } <= 2, #{ P2P-client, P2P-GO } <= 1, total <= 3, #channels <= 1 Supported commands: * new_interface * set_interface * new_key * start_ap * new_station * new_mpath * set_mesh_config * set_bss * authenticate * associate * deauthenticate * disassociate * join_ibss * join_mesh * remain_on_channel * set_tx_bitrate_mask * frame * frame_wait_cancel * set_wiphy_netns * set_channel * set_wds_peer * probe_client * set_noack_map * register_beacons * connect * disconnect Supported TX frame types: * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0 Supported RX frame types: * IBSS: 0xd0 * managed: 0x40 0xd0 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 * mesh point: 0xb0 0xc0 0xd0 * P2P-client: 0x40 0xd0 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0 WoWLAN support: * wake up on anything (device continues operating normally) * wake up on disconnect Device supports AP-side u-APSD. HT Capability overrides: * MCS: ff ff ff ff ff ff ff ff ff ff * maximum A-MSDU length * supported channel width * short GI for 40 MHz * max A-MPDU length exponent * min MPDU start spacing Device supports TX status socket option. Device supports HT-IBSS. Commands: iw dev wlan0 del 74 iw phy phy1 interface add wlan0 type __ap 110 iw phy phy1 interface add wlan1 type managed systemctl status hostapd.service Б≈■hostapd.service - LSB: Advanced IEEE 802.11 management daemon Loaded: loaded (/etc/init.d/hostapd) Active: active (running) since Mon 2016-11-14 09:52:12 CET; 5min ago Process: 845 ExecStop=/etc/init.d/hostapd stop (code=exited, status=0/SUCCESS) Process: 852 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS) CGroup: /system.slice/hostapd.service Б■■Б■─855 /usr/sbin/hostapd -B -P /run/hostapd.pid /etc/hostapd.conf Nov 14 09:52:12 orangepizero hostapd[852]: Starting advanced IEEE 802.11 management: hostapd. Nov 14 09:52:12 orangepizero systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon. systemctl status wpa_supplicant.service Б≈■wpa_supplicant.service - WPA supplicant Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; disabled) Active: active (running) since Mon 2016-11-14 09:50:58 CET; 7min ago Main PID: 681 (wpa_supplicant) CGroup: /system.slice/wpa_supplicant.service Б■■Б■─681 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant Link to comment Share on other sites More sharing options...
lekko Posted January 30, 2017 Share Posted January 30, 2017 I'm also trying to setup ap+managed. Individually, I can have a station or ap and it works fine. When I have both interfaces, only one of them is functional. One thing to keep in mind is that both station and ap need to use the same channel, as I understand it. Link to comment Share on other sites More sharing options...
asp Posted January 30, 2017 Author Share Posted January 30, 2017 I'm also trying to setup ap+managed. Individually, I can have a station or ap and it works fine. When I have both interfaces, only one of them is functional. One thing to keep in mind is that both station and ap need to use the same channel, as I understand it. I already done it using nmtui utility, but it works only on Mainline 4.9.3 Ubuntu Xenial (nightly releases). Hostapd didn't tried. So I conclude that something wrong with drivers in legacy 3.4.113 1 Link to comment Share on other sites More sharing options...
luc.small Posted January 31, 2017 Share Posted January 31, 2017 I think I am seeing the same issue in legacy 3.4.113.I can get hostapd working with wlan0 in access point only mode. Other computers can see the SSID and connect to it.I then try to configure wlan0 as two virtual interfaces:sudo iw dev wlan0 delsudo iw phy phy1 interface add wlan0_station type stationsudo iw phy phy1 interface add wlan0_ap type __apThis all works fine. ifconfig and iwconfig both list the two new interfaces: wlan0_station and wlan0_ap.I can edit /etc/network/interfaces and add entries for wlan0_station and wlan0_ap.I can use ifup to bring up both interfaces. wlan0_station connected to my home router and assigned an address via dhcp. wlan0_ap assigned a static ip address. I then start up hostapd with my hostapd.conf set to use wlan0_ap interface (interface=wlan0_ap) and the channel set to the same channel as used by my router (channel=11).Hostapd starts up normally and reports that the access point is up.But no other computers ever see the SSID of the access point and none can connect even if the SSID is manually entered.I'm out of ideas, so I'm suspecting it's a driver issue. Naturally, I would be very interested to know if anyone has got this working or if there's anything obvious I've missed. Link to comment Share on other sites More sharing options...
lekko Posted January 31, 2017 Share Posted January 31, 2017 I already done it using nmtui utility, but it works only on Mainline 4.9.3 Ubuntu Xenial (nightly releases). Hostapd didn't tried. So I conclude that something wrong with drivers in legacy 3.4.113 Do you mean that you have both AP and Station mode running simultaneously on two different network virtual interfaces by using 4.9.3? Link to comment Share on other sites More sharing options...
lekko Posted January 31, 2017 Share Posted January 31, 2017 I already done it using nmtui utility, but it works only on Mainline 4.9.3 Ubuntu Xenial (nightly releases). Hostapd didn't tried. So I conclude that something wrong with drivers in legacy 3.4.113 I was able to run AP and Client modes simultaneously by switching to the 4.9.4 kernel! Thanks! Link to comment Share on other sites More sharing options...
asp Posted January 31, 2017 Author Share Posted January 31, 2017 I was able to run AP and Client modes simultaneously by switching to the 4.9.4 kernel! Thanks! What steps you did to switch kernel on debian? 2. Do you know how not to lose second virtual interface (wifi) after restart? I tried to create rules in udev, but it didn't help me (may be i wrote wrong rule) Link to comment Share on other sites More sharing options...
luc.small Posted January 31, 2017 Share Posted January 31, 2017 2. Do you know how not to lose second virtual interface (wifi) after restart? I tried to create rules in udev, but it didn't help me (may be i wrote wrong rule) I was playing around with this last night and the following worked for me... I created an /etc/udev/rules.d/70-persistent-net.rules with the following contents: SUBSYSTEM=="ieee80211", ACTION=="add|change", ATTR{macaddress}=="aa:bb:cc:dd:ee:xx", KERNEL=="phy1", \ RUN+="/sbin/iw dev wlan0 del", \ RUN+="/sbin/iw phy phy1 interface add wlan0_station type station", \ RUN+="/sbin/iw phy phy1 interface add wlan0_ap type __ap", \ RUN+="/bin/ip link set wlan0_ap address aa:bb:cc:dd:ee:yy" Substitute aa:bb:cc:dd:ee:xx with your wlan0 mac address. For aa:bb:cc:dd:ee:yy select a mac that will be unique on your network. I just took the wlan0 mac and incremented by 1. After a reboot, ifconfig -a listed wlan0_station and wlan0_ap interfaces. (My reference for this was this blog post: http://www.0xf8.org/2016/02/using-your-raspberry-pi-zeros-usb-wifi-adapter-as-both-wifi-client-and-access-point/) Link to comment Share on other sites More sharing options...
Stephan35 Posted February 2, 2017 Share Posted February 2, 2017 Hello, I am a new user of OPI Zero , I am trying also to create wifi AP . I followed full of topic in different forum but, no success . I there anybody whos get success on this device ? (and maybe can give a tutorial to help ... ) Thanks for help Best regard Using : Armbian_5.24_Orangepizero_Debian_jessie_default_3.4.113.7z Link to comment Share on other sites More sharing options...
Stephan35 Posted February 5, 2017 Share Posted February 5, 2017 Hello, Here is some news , and some hours to get this f...... wifi get working as i wish . Bridge Eth0 to wlan0 , with dhcp and dns working # nano /etc/default/hostapd DAEMON_CONF="/etc/hostapd.conf" # nano /etc/network/interfaces # This file intentionally left blank## All interfaces are handled by network-manager, use nmtui or nmcli on# server/headless images or the "Network Manager" GUI on desktop imagesauto lo br0iface lo inet loopback # wireless wlan0allow-hotplug wlan0iface wlan0 inet manual # eth0 connected to the ISP routerallow-hotplug eth0iface eth0 inet manual # Setup bridgeiface br0 inet dhcp bridge_ports wlan0 eth0 # Lance le processus hostapd après l'initialisation des périphériques wlan0 et br0 post-up /usr/sbin/hostapd -B /etc/hostapd.conf # nano /etc/NetworkManager/NetworkManager.conf [main]plugins=ifupdown,keyfile [ifupdown]managed=true [keyfile]hostname=**YourHostName** nano /etc/hostapd/hostapd.conf # Nom du spot Wi-Fissid=**YourSSID**wpa_passphrase=**YourPassWord**wpa=2#wpa_psk=0123456789abcdef0123456789abcdef0123456789abcdef0123456789abcdefwpa_key_mgmt=WPA-PSKwpa_pairwise=CCMPrsn_pairwise=CCMP# interface wlandu Wi-Fiinterface=wlan0bridge=br0# Wi-Fi ouvert, pas d'authentification ! =0 1auth_algs=3# nl80211 avec tous les drivers Linux mac80211driver=nl80211# mode Wi-Fi(a = IEEE 802.11a, b = IEEE 802.11b, g = IEEE 802.11g)hw_mode=g# canal de fréquence Wi-Fi (1-14)channel=6logger_stdout=-1logger_stdout_level=2# Maximum number of stations allowed in station table (255)max_num_sta=5# Beacon interval in kus (1.024 ms) =50beacon_int=100# DTIM (delivery trafic information message)dtim_period=2# RTS/CTS threshold; 2347 = disabled (default)rts_threshold=2347# Fragmentation threshold; 2346 = disabled (default)fragm_threshold=2346# code paycountry_code=FR#disassoc_low_ack=1ieee80211d=1ieee80211n=1#ht_capab=[HT40+][sHORT-GI-40][RX-STBC1][DSSS_CCK-40][MAX-AMSDU-3839]require_ht=0wmm_enabled=1utf8_ssid=1 ## Accept all MAC address ###macaddr_acl=0 # nano /etc/sysctl.conf net.ipv4.ip_forward = 1 sudo sysctl -p /etc/sysctl.conf Remember to install all package with :apt-get --reinstall install xxxxx Help Sources : https://www.cyberciti.biz/faq/debian-ubuntu-linux-setting-wireless-access-point/ http://antoine-schellenberger.com/linux/2014/12/14/tips_hostapd_bridge.html If can help , i will edit on demand. Link to comment Share on other sites More sharing options...
lekko Posted March 26, 2017 Share Posted March 26, 2017 On 1/31/2017 at 1:14 AM, asp said: What steps you did to switch kernel on debian? 2. Do you know how not to lose second virtual interface (wifi) after restart? I tried to create rules in udev, but it didn't help me (may be i wrote wrong rule) I downloaded a new image from here: https://www.armbian.com/orange-pi-zero/#nightly If you want to delete a virtual network interface you can write a script that will be executed on boot. Since I used nmcli to create the interfaces I would use that to delete them as well. Link to comment Share on other sites More sharing options...
