bahtiyar57 Posted February 3 Share Posted February 3 I used armbian-config to set up boot from EMMC. Then I run dd if=/dev/zero of=/dev/mmcblk0 bs=1024 count=2048 And re-partitioned my SD Card. Rebooting with or without SD Card not possible. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted February 4 Share Posted February 4 is there any output on serial console? 0 Quote Link to comment Share on other sites More sharing options...
O to the o Posted February 14 Share Posted February 14 Hi I'm running into the same issue, this is the output i get from the serial <\r><\n> U-Boot SPL 2024.01-armbian (Feb 10 2024 - 01:33:08 +0000)<\r><\n> DRAM: 2048 MiB<\r><\n> Trying to boot from MMC2<\r><\n> Card did not respond to voltage select! : -110<\r><\n> spl: mmc init failed with error: -95<\r><\n> SPL: failed to boot from all boot devices<\r><\n> ### ERROR ### Please RESET the board ###<\r><\n> I got no idea what to search for in this case, also somehow my emmc is mmcblk2 instead of the mmcblk1 that it's refered to in every source i found so far 0 Quote Link to comment Share on other sites More sharing options...
bahtiyar57 Posted April 12 Author Share Posted April 12 I tried it in so many ways. Other images can be started from the emmc without any problems. It would be very nice if any one could help us. 0 Quote Link to comment Share on other sites More sharing options...
bahtiyar57 Posted April 28 Author Share Posted April 28 Yesterday I had same problems with my on SD Card installed Armbian. It won't boot. After a few failed attempts to boot, it did after all. Surprisingly not from the SD Card. It booted from EMMC, where was a clean Armbian installation flashed. After reboot it was no more possible for me to repeat this. 0 Quote Link to comment Share on other sites More sharing options...
O to the o Posted Sunday at 07:36 AM Share Posted Sunday at 07:36 AM What other images were you trying Bahtiyar ? I'm intending to use the banana Pi for a 3d printer and EMMC booting is the last thing holding me back. 0 Quote Link to comment Share on other sites More sharing options...
