RSS Bot Posted February 3, 2024 Posted February 3, 2024 aml-s9xx-box uses the u-boot shipped with the TV Box instead of installing a new u-boot. Because of this, armbian-install will make the box unbootable if it is run to install to emmc. This change prevents running armbian-install on aml-s9xx-box boards Changes to be committed: modified: packages/bsp/common/usr/sbin/armbian-install Description Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change. Jira reference number [AR-9999] How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [X] Tested running armbian-config and armbian-install on TV Box and it exits cleanly [X] Tested on a non TV Box that armbian-install works as expected Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas View the full article
