[Armbian build PR] - Fix broken uboot compilation for boards with multiple targets
Description
Fix regression caused by my previous PR #6248 that broke compilation for clearfog uboot. This PR refactors the patching logic to a separate function thereby making it easy to use outside uboot.sh.
During the process I also noticed that uboot_prepatch_version variable being initialized as part of that logic was not really being used anywhere. Hence removed the same.
How Has This Been Tested?
  • [X] Test build for meson-s4t7
  • [X] Test build for clearfog
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
