Orange Pi Zero - SPI1 - SPI_MOSI - Seems "weak"
SPI_SCLK is Peak-to-Peak 3.3v (no problem)
SPI_MOSI is Peak-to-Peak 165mv (whoa strange! hooked up to the o-scope)
I suspect that MOSI is "dead" in my config since the waveform matches SPI_SCLK almost exactly, so perhaps it's crosstalk or something of that sort.
I think my FEX is good.  Anybody else with experience?
Does anyone else experience this problem?
root@orangepizero:/dev# ls -al spi*
crw------- 1 root root 153, 0 Jan 28 12:17 spidev0.0
crw------- 1 root root 153, 1 Jan 28 12:17 spidev1.0
[spi0]
spi_used = 1
spi_cs_bitmap = 1
spi_mosi = port:PC00<3><default><default><default>
spi_miso = port:PC01<3><default><default><default>
spi_sclk = port:PC02<3><default><default><default>
spi_cs0 = port:PC03<3><1><default><default>
[spi1]
spi_used = 1
spi_cs_bitmap = 1
spi_cs0 = port:PA13<2><default><default><default>
spi_sclk = port:PA14<2><default><default><default>
spi_mosi = port:PA15<2><default><default><default>
spi_miso = port:PA16<2><default><default><default>
[spi_devices]
spi_dev_num = 2
[spi_board0]
modalias = "spidev"
max_speed_hz = 33000000
bus_num = 0
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
[spi_board1]
modalias = "spidev"
bus_num = 1
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
FYI Replicated this on both the OPi Zero 256 and 512mb version, so it's not a board/model specific issue.  Perhaps a SW config issue?
