mdrmdr Posted February 10, 2024 Posted February 10, 2024 (edited) I have a NanoPi Neo V1.4 running Armbian 23.8.1 bullseye with kernel nanopineo 6.1.63-current-sunxi. Now, that I got my micro-USB port working for a SD card holder, I want to programmatically backup my boot SD on a regular base to another SD. Yes, it works by a full dd-copy. but this is quite time consuming and I want to skip some directories while backup, which does not work with dd. The idea: Take a new SD (same model as source SD) Create a new partition table and a primary partition 1 with fully equal parameters as my source SD Format partition 1 with ext4 and mount to /mnt rsync all files (exclude some directories as e.g. /var/log) from source / to target / (which is /mnt/) Use this SD in case of a problem with the source SD as new boot SD In /boot/armbianEnv.txt i have rootdev=/dev/mmcblk0p1. No UUID used. But, it just does not boot. The LED's of my NanoPi stay on with no blinking at all. Nothing is written to /var/log. Unfortunately I cannot connect a console to the NanoPi to see the boot messages. Only SSH at this time. What is missing on the new SD? I assume something with the U-Boot bootloader? Can anybody help me? What is missing and needs to be copied to the SD? I assume to the bytes 512-8192 just in front of partition 1 and after the partition table. Even that a full dd works, I'd like to know how to do that manually. Thanks a lot for help 🙂 Edited February 10, 2024 by mdrmdr 0 Quote
mdrmdr Posted February 10, 2024 Author Posted February 10, 2024 (edited) Why is it always the case that after asking for help, you keep looking and then you find the solution? 😉 The SD boots using the instructions on this page: https://docs.armbian.com/User-Guide_Recovery/#flashing-boot-loader In my case using this U-Boot files: https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-u-boot-nanopineo-current/ Maybe this helps someone having the same issue. Update question: Maybe one can answer that: I did use u-boot-sunxi-with-spl.bin from the above URL, which works perfectly well. Why does the same file from https://ftp.de.debian.org/debian/dists/bullseye/main/installer-armhf/current/images/u-boot/NanoPiNeo/ not work? With the one from the Debian site, the NanoPi does not boot. To write I use: dd if=u-boot-sunxi-with-spl.bin of=/dev/sda bs=8k seek=1 Update 2: Guess I found my error. The Debian U-Boot file is just not made for an NanoPi Neo running Armbian. I'm now using the one which comes with the installation, which is /usr/lib/linux-u-boot-current-nanopineo/u-boot-sunxi-with-spl.bin. This works fine. Edited February 11, 2024 by mdrmdr 0 Quote
