Create backup boot SD by script
mdrmdr
I have a NanoPi Neo V1.4 running Armbian 23.8.1 bullseye with kernel nanopineo 6.1.63-current-sunxi.
Now, that I got my micro-USB port working for a SD card holder, I want to programmatically backup my boot SD on a regular base to another SD.
Yes, it works by a full dd-copy. but this is quite time consuming and I want to skip some directories while backup, which does not work with dd.
The idea:
  • Take a new SD (same model as source SD)
  • Create a new partition table and a primary partition 1 with fully equal parameters as my source SD
  • Format partition 1 with ext4 and mount to /mnt
  • rsync all files (exclude some directories as e.g. /var/log) from source / to target / (which is /mnt/)
  • Use this SD in case of a problem with the source SD as new boot SD
In /boot/armbianEnv.txt i have rootdev=/dev/mmcblk0p1. No UUID used.
But, it just does not boot. The LED's of my NanoPi stay on with no blinking at all. Nothing is written to /var/log.
Unfortunately I cannot connect a console to the NanoPi to see the boot messages. Only SSH at this time.
What is missing on the new SD? I assume something with the U-Boot bootloader?
Can anybody help me? What is missing and needs to be copied to the SD? I assume to the bytes 512-8192 just in front of partition 1 and after the partition table.
Even that a full dd works, I'd like to know how to do that manually.
Thanks a lot for help 🙂
Edited by mdrmdr
Why is it always the case that after asking for help, you keep looking and then you find the solution? 😉
The SD boots using the instructions on this page: https://docs.armbian.com/User-Guide_Recovery/#flashing-boot-loader
In my case using this U-Boot files: https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-u-boot-nanopineo-current/
Maybe this helps someone having the same issue.
Update question:
Maybe one can answer that: I did use u-boot-sunxi-with-spl.bin from the above URL, which works perfectly well.
Why does the same file from https://ftp.de.debian.org/debian/dists/bullseye/main/installer-armhf/current/images/u-boot/NanoPiNeo/ not work?
With the one from the Debian site, the NanoPi does not boot. To write I use: dd if=u-boot-sunxi-with-spl.bin of=/dev/sda bs=8k seek=1
Update 2:
Guess I found my error. The Debian U-Boot file is just not made for an NanoPi Neo running Armbian.
I'm now using the one which comes with the installation, which is /usr/lib/linux-u-boot-current-nanopineo/u-boot-sunxi-with-spl.bin. This works fine.
Edited by mdrmdr
