[Armbian build PR] - RFC: Add functionality to freeze git resources
Description
The idea is to generate output/git_sources.json file that will contain url, branch and commit hash combo. The easiest way to generate file for all devices is to run ./compile.sh targets. Then at the time of release we will copy the output/git_sources.json file to config/sources/git_sources.json. Once the file is copied, the hash information from the file will be used to fetch resources for git repositories where branches are specified instead of tags or commits.
There can be other ways to do this as well. I am just too tired to experiment more on the same. Raising it to be a communication starter.
I have also added the json file that I have generated today. I think it can be used to freeze sources for 24.02 release. Hence I have raised this PR again v24.02 branch
How Has This Been Tested?
  • [ ] Tested output/git_sources.json file generation using ./compile.sh targets command
  • [ ] Copied generated file to config/sources and modified it to use a different commit hash for 6.6 kernel. Then tested that kernel is being built from that hash instead of the latest available 6.6 kernel.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
