RSS Bot Posted February 13, 2024 Posted February 13, 2024 Description This patch fixes the high interrupt issue on the Orange Pi5 Plus. Forum discussion available here. https://forum.armbian.com/topic/33360-orangepi-5-plus-rtc-hym8563-irq-issue/ The patch also adds poweroff support. Right now the Orange Pi 5 Plus just reboots when poweroff or shutdown -h now is executed. Third fix of the patch is to correct gpio_pwrctrl1 typo. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Build command ./compile.sh BOARD=orangepi5-plus BRANCH=edge RELEASE=trixie KERNEL_CONFIGURE=no BUILD_MINIMAL=yes BUILD_DESKTOP=no COMPRESS_OUTPUTIMAGE=img BOOTSIZE=512 [x] Booted the image and went through the first-run wizard [x] Checked the system via top and procinfo and monitored the cpu usage and interrupts Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
