mkII Posted February 4, 2017 Posted February 4, 2017 This was my second attempt and it finished with exactly the same result. Console log: ~$ ssh admin@zero ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.113-sun8i System load: 0.07 Up time: 3 min Memory usage: 9 % of 494Mb IP: 192.168.8.91 CPU temp: 34°C Usage of /: 18% of 7.2G [ 7 updates to install: apt-get upgrade ] Last login: Sat Feb 4 14:15:58 2017 from 192.168.8.111 ----------------------------------------------------------------------- 16:26:25 admin@zero:~$ sudo apt-get upgrade -y Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-firmware armbian-tools-jessie hostapd linux-headers-sun8i linux-image-sun8i linux-jessie-root-orangepizero linux-u-boot-orangepizero-default 7 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/20.9 MB of archives. After this operation, 2,142 kB of additional disk space will be used. (Reading database ... 57509 files and directories currently installed.) Preparing to unpack .../armbian-firmware_5.25_armhf.deb ... Unpacking armbian-firmware (5.25) over (5.24) ... Preparing to unpack .../armbian-tools-jessie_5.25_armhf.deb ... Unpacking armbian-tools-jessie (5.25) over (5.24) ... Preparing to unpack .../hostapd_1%3a2.5~armbian5.25+1_armhf.deb ... Unpacking hostapd (1:2.5~armbian5.25+1) over (1:2.5~armbian5.24.161202+1) ... Preparing to unpack .../linux-headers-sun8i_5.25_armhf.deb ... Unpacking linux-headers-sun8i (5.25) over (5.24) ... Preparing to unpack .../linux-image-sun8i_5.25_armhf.deb ... Unpacking linux-image-sun8i (5.25) over (5.24) ... Preparing to unpack .../linux-jessie-root-orangepizero_5.25_armhf.deb ... Leaving 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-orangepizero' Unpacking linux-jessie-root-orangepizero (5.25) over (5.24) ... /var/lib/dpkg/info/linux-jessie-root-orangepizero.postrm: 2: [: missing ] Preparing to unpack .../linux-u-boot-orangepizero-default_5.25_armhf.deb ... Unpacking linux-u-boot-orangepizero-default (5.25) over (5.24) ... Processing triggers for systemd (215-17+deb8u6) ... Processing triggers for man-db (2.7.0.2-5) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Setting up armbian-firmware (5.25) ... Setting up armbian-tools-jessie (5.25) ... Setting up hostapd (1:2.5~armbian5.25+1) ... Setting up linux-headers-sun8i (5.25) ... Compiling headers - please wait ... Setting up linux-image-sun8i (5.25) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Setting up linux-jessie-root-orangepizero (5.25) ... Setting up linux-u-boot-orangepizero-default (5.25) ... Updating u-boot on device /dev/mmcblk0 Processing triggers for initramfs-tools (0.120+deb8u2) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Scanning processes... Scanning candidates... Scanning kernel images... Failed to retrieve available kernel versions. Restarting services using systemd... ----------------------------------------------------------------------- 16:31:19 admin@zero:~$ ls -lh /boot total 14M -rw-r--r-- 1 root root 123 Feb 4 14:20 armbianEnv.txt drwxr-xr-x 2 root root 4.0K Feb 4 16:29 bin drwxr-xr-x 2 root root 4.0K Nov 14 13:13 bin.old -rw-r--r-- 1 root root 6.8K Nov 14 13:14 boot.bmp -rw-r--r-- 1 root root 2.0K Nov 14 13:10 boot.cmd -rw-r--r-- 1 root root 2.1K Nov 14 13:15 boot.scr -rw-r--r-- 1 root root 95K Feb 2 06:01 config-3.4.113-sun8i -rw-r--r-- 1 root root 3.7M Feb 4 16:30 initrd.img-3.4.113-sun8i lrwxrwxrwx 1 root root 20 Nov 14 13:13 script.bin -> bin/orangepizero.bin -rw-r--r-- 1 root root 2.0M Feb 2 06:01 System.map-3.4.113-sun8i lrwxrwxrwx 1 root root 21 Feb 4 16:30 uInitrd -> uInitrd-3.4.113-sun8i -rw-r--r-- 1 root root 3.7M Feb 4 16:30 uInitrd-3.4.113-sun8i -rwxr-xr-x 1 root root 4.6M Feb 2 06:01 vmlinuz-3.4.113-sun8i lrwxrwxrwx 1 root root 21 Feb 4 16:30 zImage -> vmlinuz-3.4.113-sun8i ----------------------------------------------------------------------- 16:32:50 admin@zero:~$ sudo cat /etc/network/interfaces # Wired adapter #1 allow-hotplug eth0 #no-auto-down eth0 iface eth0 inet dhcp #address 192.168.0.100 #netmask 255.255.255.0 #gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # hwaddress ether # if you want to set MAC manually # pre-up /sbin/ifconfig eth0 mtu 3838 # setting MTU for DHCP, static just: mtu 3838 link-speed 10 link-duplex full ethernet-autoneg off # Wireless adapter #1 # Armbian ships with network-manager installed by default. To save you time # and hassles consider using 'sudo nmtui' instead of configuring Wi-Fi settings # manually. The below lines are only meant as an example how configuration could # be done in an anachronistic way: # #allow-hotplug wlan0 #iface wlan0 inet dhcp #address 192.168.0.100 #netmask 255.255.255.0 #gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf # Disable power saving on compatible chipsets (prevents SSH/connection dropouts over WiFi) #wireless-mode Managed #wireless-power off # Local loopback auto lo iface lo inet loopback ----------------------------------------------------------------------- 16:33:27 admin@zero:~$ pstree systemd─┬─NetworkManager─┬─{NetworkManager} │ ├─{gdbus} │ └─{gmain} ├─2*[agetty] ├─cron ├─dbus-daemon ├─dhclient ├─haveged ├─lircd ├─ntpd ├─polkitd─┬─{gdbus} │ └─{gmain} ├─rsyslogd─┬─{in:imklog} │ ├─{in:imuxsock} │ └─{rs:main Q:Reg} ├─sshd───sshd───sshd───bash───pstree ├─systemd───(sd-pam) ├─systemd-journal ├─systemd-logind ├─systemd-udevd └─wpa_supplicant ----------------------------------------------------------------------- 16:35:03 admin@zero:~$ sudo reboot Connection to zero closed by remote host. Connection to zero closed. ----------------------------------------------------------------------- 16:35:13 ~$ ssh admin@zero ^C ----------------------------------------------------------------------- 16:40:15 ~$ nmap zero Starting Nmap 7.40 ( https://nmap.org ) at 2017-02-04 16:53 YEKT Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn Nmap done: 1 IP address (0 hosts up) scanned in 3.98 seconds ----------------------------------------------------------------------- 16:53:27 ~$ nmap -Pn zero Starting Nmap 7.40 ( https://nmap.org ) at 2017-02-04 16:53 YEKT Nmap scan report for zero (192.168.8.91) Host is up (0.00013s latency). All 1000 scanned ports on zero (192.168.8.91) are filtered Nmap done: 1 IP address (1 host up) scanned in 14.23 seconds ----------------------------------------------------------------------- 16:53:50 ~$ After previous attempt I just restored SD card from saved image, so I can do it again, sure, but it means that I can't use subsequent releases. Thanks.
jkajolin Posted February 4, 2017 Posted February 4, 2017 Ubuntu xenial is a lot more stable use it instead. I have had several devices where after the upgrade the device fails to boot no more. Downloaded a new image an worked again (I think it was orange pi pc plus debian last time...). This was my second attempt and it finished with exactly the same result. Console log: ~$ ssh admin@zero ___ ____ _ _____ / _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) |__ /___ _ __ ___ | | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | / // _ \ '__/ _ \ | |_| | | | (_| | | | | (_| | __/ | __/| | / /| __/ | | (_) | \___/|_| \__,_|_| |_|\__, |\___| |_| |_| /____\___|_| \___/ |___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.113-sun8i System load: 0.07 Up time: 3 min Memory usage: 9 % of 494Mb IP: 192.168.8.91 CPU temp: 34°C Usage of /: 18% of 7.2G [ 7 updates to install: apt-get upgrade ] Last login: Sat Feb 4 14:15:58 2017 from 192.168.8.111 ----------------------------------------------------------------------- 16:26:25 admin@zero:~$ sudo apt-get upgrade -y Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-firmware armbian-tools-jessie hostapd linux-headers-sun8i linux-image-sun8i linux-jessie-root-orangepizero linux-u-boot-orangepizero-default 7 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/20.9 MB of archives. After this operation, 2,142 kB of additional disk space will be used. (Reading database ... 57509 files and directories currently installed.) Preparing to unpack .../armbian-firmware_5.25_armhf.deb ... Unpacking armbian-firmware (5.25) over (5.24) ... Preparing to unpack .../armbian-tools-jessie_5.25_armhf.deb ... Unpacking armbian-tools-jessie (5.25) over (5.24) ... Preparing to unpack .../hostapd_1%3a2.5~armbian5.25+1_armhf.deb ... Unpacking hostapd (1:2.5~armbian5.25+1) over (1:2.5~armbian5.24.161202+1) ... Preparing to unpack .../linux-headers-sun8i_5.25_armhf.deb ... Unpacking linux-headers-sun8i (5.25) over (5.24) ... Preparing to unpack .../linux-image-sun8i_5.25_armhf.deb ... Unpacking linux-image-sun8i (5.25) over (5.24) ... Preparing to unpack .../linux-jessie-root-orangepizero_5.25_armhf.deb ... Leaving 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-orangepizero' Unpacking linux-jessie-root-orangepizero (5.25) over (5.24) ... /var/lib/dpkg/info/linux-jessie-root-orangepizero.postrm: 2: [: missing ] Preparing to unpack .../linux-u-boot-orangepizero-default_5.25_armhf.deb ... Unpacking linux-u-boot-orangepizero-default (5.25) over (5.24) ... Processing triggers for systemd (215-17+deb8u6) ... Processing triggers for man-db (2.7.0.2-5) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Setting up armbian-firmware (5.25) ... Setting up armbian-tools-jessie (5.25) ... Setting up hostapd (1:2.5~armbian5.25+1) ... Setting up linux-headers-sun8i (5.25) ... Compiling headers - please wait ... Setting up linux-image-sun8i (5.25) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Setting up linux-jessie-root-orangepizero (5.25) ... Setting up linux-u-boot-orangepizero-default (5.25) ... Updating u-boot on device /dev/mmcblk0 Processing triggers for initramfs-tools (0.120+deb8u2) ... update-initramfs: Generating /boot/initrd.img-3.4.113-sun8i update-initramfs: Converting to u-boot format Scanning processes... Scanning candidates... Scanning kernel images... Failed to retrieve available kernel versions. Restarting services using systemd... ----------------------------------------------------------------------- 16:31:19 admin@zero:~$ ls -lh /boot total 14M -rw-r--r-- 1 root root 123 Feb 4 14:20 armbianEnv.txt drwxr-xr-x 2 root root 4.0K Feb 4 16:29 bin drwxr-xr-x 2 root root 4.0K Nov 14 13:13 bin.old -rw-r--r-- 1 root root 6.8K Nov 14 13:14 boot.bmp -rw-r--r-- 1 root root 2.0K Nov 14 13:10 boot.cmd -rw-r--r-- 1 root root 2.1K Nov 14 13:15 boot.scr -rw-r--r-- 1 root root 95K Feb 2 06:01 config-3.4.113-sun8i -rw-r--r-- 1 root root 3.7M Feb 4 16:30 initrd.img-3.4.113-sun8i lrwxrwxrwx 1 root root 20 Nov 14 13:13 script.bin -> bin/orangepizero.bin -rw-r--r-- 1 root root 2.0M Feb 2 06:01 System.map-3.4.113-sun8i lrwxrwxrwx 1 root root 21 Feb 4 16:30 uInitrd -> uInitrd-3.4.113-sun8i -rw-r--r-- 1 root root 3.7M Feb 4 16:30 uInitrd-3.4.113-sun8i -rwxr-xr-x 1 root root 4.6M Feb 2 06:01 vmlinuz-3.4.113-sun8i lrwxrwxrwx 1 root root 21 Feb 4 16:30 zImage -> vmlinuz-3.4.113-sun8i ----------------------------------------------------------------------- 16:32:50 admin@zero:~$ sudo cat /etc/network/interfaces # Wired adapter #1 allow-hotplug eth0 #no-auto-down eth0 iface eth0 inet dhcp #address 192.168.0.100 #netmask 255.255.255.0 #gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # hwaddress ether # if you want to set MAC manually # pre-up /sbin/ifconfig eth0 mtu 3838 # setting MTU for DHCP, static just: mtu 3838 link-speed 10 link-duplex full ethernet-autoneg off # Wireless adapter #1 # Armbian ships with network-manager installed by default. To save you time # and hassles consider using 'sudo nmtui' instead of configuring Wi-Fi settings # manually. The below lines are only meant as an example how configuration could # be done in an anachronistic way: # #allow-hotplug wlan0 #iface wlan0 inet dhcp #address 192.168.0.100 #netmask 255.255.255.0 #gateway 192.168.0.1 #dns-nameservers 8.8.8.8 8.8.4.4 # wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf # Disable power saving on compatible chipsets (prevents SSH/connection dropouts over WiFi) #wireless-mode Managed #wireless-power off # Local loopback auto lo iface lo inet loopback ----------------------------------------------------------------------- 16:33:27 admin@zero:~$ pstree systemd─┬─NetworkManager─┬─{NetworkManager} │ ├─{gdbus} │ └─{gmain} ├─2*[agetty] ├─cron ├─dbus-daemon ├─dhclient ├─haveged ├─lircd ├─ntpd ├─polkitd─┬─{gdbus} │ └─{gmain} ├─rsyslogd─┬─{in:imklog} │ ├─{in:imuxsock} │ └─{rs:main Q:Reg} ├─sshd───sshd───sshd───bash───pstree ├─systemd───(sd-pam) ├─systemd-journal ├─systemd-logind ├─systemd-udevd └─wpa_supplicant ----------------------------------------------------------------------- 16:35:03 admin@zero:~$ sudo reboot Connection to zero closed by remote host. Connection to zero closed. ----------------------------------------------------------------------- 16:35:13 ~$ ssh admin@zero ^C ----------------------------------------------------------------------- 16:40:15 ~$ nmap zero Starting Nmap 7.40 ( https://nmap.org ) at 2017-02-04 16:53 YEKT Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn Nmap done: 1 IP address (0 hosts up) scanned in 3.98 seconds ----------------------------------------------------------------------- 16:53:27 ~$ nmap -Pn zero Starting Nmap 7.40 ( https://nmap.org ) at 2017-02-04 16:53 YEKT Nmap scan report for zero (192.168.8.91) Host is up (0.00013s latency). All 1000 scanned ports on zero (192.168.8.91) are filtered Nmap done: 1 IP address (1 host up) scanned in 14.23 seconds ----------------------------------------------------------------------- 16:53:50 ~$ After previous attempt I just restored SD card from saved image, so I can do it again, sure, but it means that I can't use subsequent releases. Thanks.
mkII Posted February 4, 2017 Author Posted February 4, 2017 Ubuntu xenial is a lot more stable use it instead. I have had several devices where after the upgrade the device fails to boot no more. Downloaded a new image an worked again (I think it was orange pi pc plus debian last time...). Ok, thanks, I'll try.
