RSS Bot Posted February 18, 2024 Posted February 18, 2024 Description Enable uboot gpio command. This would allow to set up rk3318-box'es LED display in custom uboot script. For example, to show "boot", this snippet can be added (gpio pins and letter codes should be adjusted for different STB/LCD models): FD650_MODE_WRCMD='0 1 0 0 1 0 0 0' DISPON='0 0 0 0 0 0 0 1' FD655_BASE_ADDR='0 1 1 0 0 1 1 0' Z='0 0 0 0 0 0 0 0' B='0 1 1 0 0 1 1 1' O='0 1 1 0 0 0 1 1' T='0 1 0 0 0 1 1 1' setenv d0 gpio clear C22 setenv d1 gpio set C22 setenv LC gpio clear C19 setenv HC gpio set C19 setenv send 'run d0 LC; for b in $cmd; do run d$b HC LC; done; run HC d1' cmd="$FD650_MODE_WRCMD 1 $DISPON 1" run send cmd="$FD655_BASE_ADDR 1 $Z 1 $B 1 $O 1 $O 1 $T 1" run send How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Compile and boot rk3318-box Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
