RSS Bot Posted February 19, 2024 Posted February 19, 2024 Changes to be committed: modified: config/boards/aml-s9xx-box.tvb deleted: packages/bsp/aml-s9xx-box/boot/extlinux/extlinux.conf new file: packages/bsp/aml-s9xx-box/boot/extlinux/extlinux.conf.template Description Upgrades of the aml-s9xx-box bsp package were failing (apparently I've never tested this, nor has anyone reported it) The problem is that the package installs files into /boot which is a fat filesystem. dpkg doesn't support the fat filesystem for upgrades as it tries to create a backup link for each file it is replacing which fails. Solution is to remove the files being replaced in a preinst step This also necessitated using the standard armbian extlinux.conf file as installing a custom one would result in the extlinux.conf file being replaced (without the append line being added, thus making the box unbootable after upgrade) Jira reference number [AR-9999] How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Tested new image works [x] Tested upgrading and reinstalling the armbian-bsp-cli-aml-s9xx-box-current deb Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas View the full article
