[Armbian build PR] - BigTreeTech CB1: fix mmc probe failure due to regulator not being available
Description
The user idubrov reported on forums and discord that the current and edge images are not bootable from sdcard as mmc driver fails to probe due to regulator not being available. This is a regression that happened due to switching from bigtreetech provided axp313a driver to mainline axp313a driver. Updating regulator node name in dts apparently makes it work with the upstream driver as tested by the user.
I have also noticed that CI was not covering current and edge kernel for this board. I have enabled the same to make sure we will be aware of such issues in the future.
How Has This Been Tested?
  • [X] Tested only that patches apply correctly as I don't really have the board.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [ ] My changes generate no new warnings
View the full article
