Hi again,
  For a dedicated digital audio system (squeezebox) I would like to set up my Pine64 board with a preemptible kernel.
I have been trying to use the  procedure from
  https://docs.armbian.com/Developer-Guide_Build-Preparation/
to build a patched 3.10.104 kernel using the RT patch from:
 https://www.kernel.org/pub/linux/kernel/projects/rt/3.10/
patch-3.10.104-rt117 patch set
The patches are applied successfully by the script, but break a number of things so the kernel doesn't compile.
A number of the problems are linked to ip tunnelling, which I simply removed from the config as my system won't need them, but now I'm hitting:
 MODPOST vmlinux.o        │
  │ WARNING: modpost: Found 2 section mismatch(es).        │
  │ To see full details build your kernel with:        │
  │ 'make CONFIG_DEBUG_SECTION_MISMATCH=y'        │
  │   GEN     .version        │
  │   CHK     include/generated/compile.h        │
  │   UPD     include/generated/compile.h        │
  │   CC      init/version.o        │
  │   LD      init/built-in.o        │
  │ drivers/built-in.o: In function `mbus_pmu_remove':        │
  │ arisc_dram_crc.c:(.text+0x1d38): undefined reference to `hwmon_device_unregister'        │
  │ arisc_dram_crc.c:(.text+0x1d38): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `hwmon_device_unregister'                │
  │ drivers/built-in.o: In function `mbus_pmu_probe':
which looks harder to fix.
Can anyone help by pointing to a RT patch set that is better suited to the A64?
BR.
--Marius--
To answer my first question (and ask another):
 CONFIG_HWMON was set to be a loadable module. I chenged it to compile in ( CONFIG_HWMON=y ) and the build went through.
BUT, now I'm facing a new issue with the script.
at the end of the build process, it loks as if the deb package is not being built:
...  │   INSTALL include/asm (35 files)        │
  │ /home/marius/temp/sources/linux-pine64/pine64-hacks-1.2/scripts/package/Makefile:90: recipe for target 'deb-pkg' failed        â”‚
  │ make[1]: *** [deb-pkg] Error 1        │
  │ Makefile:1082: recipe for target 'deb-pkg' failed        â”‚
  │ make: *** [deb-pkg] Error 2        â”‚
mv: cannot stat '*.deb': No such file or directory
[ error ] ERROR in function compile_kernel [ common.sh:273 ]
[ error ] Failed moving kernel DEBs
[ o.k. ] Process terminated ...
Looking at common.sh line 273 (last line) I see:
# produce deb packages: image, headers, firmware, dtb        eval CCACHE_BASEDIR="$(pwd)" ${toolchain:+env PATH=$toolchain:$PATH} \
                'make -j1 $KERNEL_PACKING KDEB_PKGVERSION=$REVISION LOCALVERSION="-"$LINUXFAMILY \
                KBUILD_DEBARCH=$ARCH ARCH=$ARCHITECTURE DEBFULLNAME="$MAINTAINER" DEBEMAIL="$MAINTAINERMAIL" CROSS_COMPILE="$CCACHE $KERNEL_COMPILER" 2>&1' \
                ${PROGRESS_LOG_TO_FILE:+' | tee -a $DEST/debug/compilation.log'} \
                ${OUTPUT_DIALOG:+' | dialog --backtitle "$backtitle" --progressbox "Creating kernel packages..." $TTY_Y $TTY_X'} \
                ${OUTPUT_VERYSILENT:+' >/dev/null 2>/dev/null'}
        cd ..
        mv *.deb $DEST/debs/ || exit_with_error "Failed moving kernel DEBs"
Any way to try running gthe script from that point with some extra debugging....to see why it's breaking?
BR.
