Learnincurve Posted February 8, 2017 Share Posted February 8, 2017 Hi again, For a dedicated digital audio system (squeezebox) I would like to set up my Pine64 board with a preemptible kernel. I have been trying to use the procedure from https://docs.armbian.com/Developer-Guide_Build-Preparation/ to build a patched 3.10.104 kernel using the RT patch from: https://www.kernel.org/pub/linux/kernel/projects/rt/3.10/ patch-3.10.104-rt117 patch set The patches are applied successfully by the script, but break a number of things so the kernel doesn't compile. A number of the problems are linked to ip tunnelling, which I simply removed from the config as my system won't need them, but now I'm hitting: MODPOST vmlinux.o │ │ WARNING: modpost: Found 2 section mismatch(es). │ │ To see full details build your kernel with: │ │ 'make CONFIG_DEBUG_SECTION_MISMATCH=y' │ │ GEN .version │ │ CHK include/generated/compile.h │ │ UPD include/generated/compile.h │ │ CC init/version.o │ │ LD init/built-in.o │ │ drivers/built-in.o: In function `mbus_pmu_remove': │ │ arisc_dram_crc.c:(.text+0x1d38): undefined reference to `hwmon_device_unregister' │ │ arisc_dram_crc.c:(.text+0x1d38): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `hwmon_device_unregister' │ │ drivers/built-in.o: In function `mbus_pmu_probe': which looks harder to fix. Can anyone help by pointing to a RT patch set that is better suited to the A64? BR. --Marius-- Link to comment Share on other sites More sharing options...
Learnincurve Posted February 8, 2017 Author Share Posted February 8, 2017 To answer my first question (and ask another): CONFIG_HWMON was set to be a loadable module. I chenged it to compile in ( CONFIG_HWMON=y ) and the build went through. BUT, now I'm facing a new issue with the script. ' at the end of the build process, it loks as if the deb package is not being built: ... ... │ INSTALL include/asm (35 files) │ │ /home/marius/temp/sources/linux-pine64/pine64-hacks-1.2/scripts/package/Makefile:90: recipe for target 'deb-pkg' failed │ │ make[1]: *** [deb-pkg] Error 1 │ │ Makefile:1082: recipe for target 'deb-pkg' failed │ │ make: *** [deb-pkg] Error 2 │ └────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ mv: cannot stat '*.deb': No such file or directory [ error ] ERROR in function compile_kernel [ common.sh:273 ] [ error ] Failed moving kernel DEBs [ o.k. ] Process terminated ... ... Looking at common.sh line 273 (last line) I see: # produce deb packages: image, headers, firmware, dtb eval CCACHE_BASEDIR="$(pwd)" ${toolchain:+env PATH=$toolchain:$PATH} \ 'make -j1 $KERNEL_PACKING KDEB_PKGVERSION=$REVISION LOCALVERSION="-"$LINUXFAMILY \ KBUILD_DEBARCH=$ARCH ARCH=$ARCHITECTURE DEBFULLNAME="$MAINTAINER" DEBEMAIL="$MAINTAINERMAIL" CROSS_COMPILE="$CCACHE $KERNEL_COMPILER" 2>&1' \ ${PROGRESS_LOG_TO_FILE:+' | tee -a $DEST/debug/compilation.log'} \ ${OUTPUT_DIALOG:+' | dialog --backtitle "$backtitle" --progressbox "Creating kernel packages..." $TTY_Y $TTY_X'} \ ${OUTPUT_VERYSILENT:+' >/dev/null 2>/dev/null'} cd .. mv *.deb $DEST/debs/ || exit_with_error "Failed moving kernel DEBs" Any way to try running gthe script from that point with some extra debugging....to see why it's breaking? BR. Link to comment Share on other sites More sharing options...
