[Armbian build PR] - Add board BananaPi M4 Zero
Picks up from where we left off; https://github.com/armbian/build/pull/6296 Stable wireless depends on the following PR; https://github.com/armbian/build/pull/6314
Notables: Updated U-Boot to v2024.01
U-Boot SPL 2024.01-armbian (Feb 29 2024 - 04:57:24 -0500)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.10.2(debug):armbian
NOTICE:  BL31: Built : 04:56:45, Feb 29 2024
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a09ca98, model: BananaPi M4 Zero
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP305 on RSB
ERROR:   RSB: set run-time address: 0x10003
INFO:    Could not init RSB: -65539
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2024.01-armbian (Feb 29 2024 - 04:57:24 -0500) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: BananaPi M4 Zero
DRAM:  2 GiB
Core:  52 devices, 21 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
Bus usb@5311400: USB OHCI 1.0
scanning bus usb@5311400 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3259 bytes read in 3 ms (1 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
205 bytes read in 2 ms (99.6 KiB/s)
31833 bytes read in 11 ms (2.8 MiB/s)
Working FDT set to 4fa00000
4203 bytes read in 7 ms (585.9 KiB/s)
Applying kernel provided DT fixup script (sun50i-h616-fixup.scr)
## Executing script at 45000000
18347702 bytes read in 2961 ms (5.9 MiB/s)
23365640 bytes read in 3770 ms (5.9 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=418d0000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Data Size:    18347638 Bytes = 17.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 48e80000, end 49fff676 ... OK
   Loading Device Tree to 0000000048e0f000, end 0000000048e7ffff ... OK
Working FDT set to 48e0f000
Starting kernel ...
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
