joekhoobyar Posted March 1 Share Posted March 1 Step 1 - Install the Armbian PGP key and update your APT sources Install armbian.gpg to /usr/share/keyrings/armbian.gpg (mode 644) You can use a copy from another one of your SBCs, or... ... you can download and install like below (thanks @BrewNinja for the example) touch /usr/share/keyrings/armbian.gpg chmod 644 /usr/share/keyrings/armbian.gpg wget https://apt.armbian.com/armbian.key -O - | gpg --dearmor >/usr/share/keyrings/armbian.gpg Edit /etc/apt/sources.list Replace all instances of bullseye with bookworm Edit /etc/apt/sources.list.d/armbian.list deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop Edit any other files in /etc/apt/sources.list.d as appropriate, to replace bullseye with bookworm Step 2 apt update Step 3 NOTE - WHEN RUNNING THE BELOW COMMANDS, DO NOT ACCEPT ANY INTERACTIVE PROMPTS FOR CHANGING /etc/initramfs-tools/initramfs.conf The default is not to accept the changes anyway - but I am noting this here to be extra careful I've checked - the changes may differ from what armbian has in the latest images apt upgrade --no-new-pkgs apt full-upgrade apt dist-upgrade 1 Quote Link to comment Share on other sites More sharing options...
BrewNinja Posted March 4 Share Posted March 4 Just wanted to say thank you for the instructions, they worked really well. I can add that this is how I added the armbian.gpg to my install: sudo wget https://apt.armbian.com/armbian.key -O key sudo gpg --dearmor < key | sudo tee /usr/share/keyrings/armbian.gpg > /dev/null sudo chmod go+r /usr/share/keyrings/armbian.gpg 1 Quote Link to comment Share on other sites More sharing options...
porg Posted March 5 Share Posted March 5 (edited) In the OpenMediaVault forums I reported Seemingly cannot update and upgrade anymore due to repository having no release file (OMV6 on Armbian on Odroid HC1) So if my OMV 6 with Armbian Bullseye both have not updated for a while, will this your instruction let me run apt update and apt upgrade again and also omv-upgrade? Note: As omv-upgrade in OMV 6 did not work anymore, I thought to omv-release-upgrade to OMV 7 right away. But that upgrade script included an implicit omv-upgrade too. So failed too. Hence I had then run an omv-release-upgrade (with its omv-upgrade line outcommented) which resulted in a broken system: Armbian seemingly up to date, but all OMV stuff gone or stuck in v6. I restored my SD-card with OMV6/Armbian-Bullseye from my openmediavault-backup with fsarchiver successfully. Now I would like to do things correct. Hence my questions regarding your steps: Ad 1) a) From where shall I get that armbian.gpg file reliably? Is it cryptographically ok/safe enough as @BrewNinja did it? Note: Hobby NAS on a private LAN with no services exposed to the Internet, LAN only services) If ok, then please integrate into your instruction for TL;DR users. Thanks! b) /etc/apt/sources.list is empty Ad 3) That part is hard to understand for someone who deals with SBC / Armbian only occasionally. How do I ensure apt to not make any changes to /etc/initramfs-tools/initramfs.conf ? Please clarify that. Do you mean there are interactive questions which I shall answer accordingly? Or do I need to lock something? Or monitor something and revert it if changed? Ad "4")? Then comes another code block with "apt upgrade --no-new-pkgs ; apt full-upgrade ; apt dist-upgrade" — Is this step 4? Or preceding part 3? Edited March 5 by porg 0 Quote Link to comment Share on other sites More sharing options...
porg Posted March 5 Share Posted March 5 (edited) Was able to omv-release-upgrade my Odroid HC2 from my restored OMV6 to OMV7 simply by having the single line in /etc/apt/sources.list.d/armbian.list commented out. Now I will just need to figure out how to update Armbian itself. Edited March 5 by porg 0 Quote Link to comment Share on other sites More sharing options...
joekhoobyar Posted March 6 Author Share Posted March 6 Hi @porg, Quote From where shall I get that armbian.gpg file reliably? Is it cryptographically ok/safe enough as @BrewNinja did it? Yes, it should be fine to do it as @BrewNinja did - but you can also copy from another machine on your LAN. Quote How do I ensure apt to not make any changes to /etc/initramfs-tools/initramfs.conf ? There are interactive questions - if it asks you if you want to update that file, tell it not to (which is the default anyway) 0 Quote Link to comment Share on other sites More sharing options...
Hannes Posted March 7 Share Posted March 7 (edited) Thx folks for the upgrade instructions. Worked for me until I got this (when running the standard 'apt update && apt upgrade'): The following packages have been kept back: libffi-dev libsigrokdecode4 libssl-dev 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. Then it turns out that the system has broken dependencies (or what ever may be the reason). For example if I try to update rock@nextcloud:/etc/apt/sources.list.d$ sudo apt -f install libpython3.11 Reading package lists... Done Building dependency tree... Done Some packages could not be installed [...] The following packages have unmet dependencies: libpython3.11 : Depends: libpython3.11-stdlib (= 3.11.2-6) but 3.11.7-2 is to be installed E: Unable to correct problems, you have held broken packages. But when I try updating to the required version of "libpython3.11-stdlib" it says that it's already installed: rock@nextcloud:/etc/apt/sources.list.d$ sudo apt -f install libpython3.11-stdlib Reading package lists... Done Building dependency tree... Done libpython3.11-stdlib is already the newest version (3.11.7-2). 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. And this is the case for other libraries, too. So I am not sure whether there is something wrong in gerenal ???!!!??? Info: I already tried cleaning apt and its corresponding /var/lib/apt/ dir several times. Please help ... Edited March 7 by Hannes 0 Quote Link to comment Share on other sites More sharing options...
joekhoobyar Posted March 9 Author Share Posted March 9 @Hannes it looks like you have "held packages" - this tells apt that you do not want it to upgrade them. 0 Quote Link to comment Share on other sites More sharing options...
Hannes Posted March 10 Share Posted March 10 Thx for your answer, Joekhoobyar. Yes, indeed, there are messages about "held BROKEN packages", but I did not put any packages on hold. Neither 'sudo apt-mark showhold' nor 'sudo apt-mark unhold' shows anything. What to do? I am a little bit of lost. What is the reason for this mismatch? How to get rid of it? 0 Quote Link to comment Share on other sites More sharing options...
