Lost network in rock-3a after upgrading to 24.2.1
Go to solution Solved by Jose Luis,
after upgrading linux-u-boot-rock-3a-current, linux-image-current-rockchip64 and linux-dtb-current-rockchip64 to the 24.2.1 versions, the system losses the network producing kernel errors in dmesg:
[  432.408850] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[  432.410880] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[  432.410929] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay.
[  432.410954] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30
[  432.410983] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay.
[  432.411002] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10
[  432.411051] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[  432.411223] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[  432.416282] rk_gmac-dwmac fe010000.ethernet: init for RGMII_ID
[  432.417113] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[  432.417176] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[  432.417205] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[  432.417227] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[  432.417248] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[  432.417268] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[  432.417287] rk_gmac-dwmac fe010000.ethernet: TSO supported
[  432.417306] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[  432.417336] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[  432.417369] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[  432.417391] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[  432.506616] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0
[  432.569725] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  432.571832] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19)
I went back to the 23.11.1 versions of the packages and the system has the network back:
-rwxr-xr-x 1 root root   319396 Mar  3 10:40 linux-dtb-current-rockchip64_23.11.1_arm64__6.1.63-S69e4-Df461-P59b3-C3542Hfe66-HK01ba-Vc222-B1743-R448a.deb
-rwxr-xr-x 1 root root 41712668 Mar  3 10:40 linux-image-current-rockchip64_23.11.1_arm64__6.1.63-S69e4-Df461-P59b3-C3542Hfe66-HK01ba-Vc222-B1743-R448a.deb
-rwxr-xr-x 1 root root  1036380 Mar  3 10:40 linux-u-boot-rock-3a-current_23.11.1_arm64__2017.09-Sc559-Pedff-H8c72-Vda90-B1179-R448a.deb
Using these packages, this is the output from dmesg:
[    6.259295] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    6.259807] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    6.260113] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    6.260133] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[    6.260147] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[    6.260171] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    6.260276] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    6.274301] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    6.285273] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    6.285315] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    6.285330] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    6.285340] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    6.285349] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    6.285357] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    6.285504] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    6.285518] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    6.285533] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    6.285547] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    6.285558] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    6.360605] spi-nor spi4.0: mx25u12835f (16384 Kbytes)
[    6.599788] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0
[   21.045985] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   21.139671] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   21.147558] dwmac4: Master AXI performs any burst length
[   21.147613] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found
[   21.147647] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[   21.148015] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock
[   21.155727] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode
[   25.295999] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
[   25.296059] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready
Thanks in advance.
support.txtFetching info... dmesg.txtFetching info...
Edited by Jose Luis
Doing more tests, I've upgraded linux-image-current-rockchip64 to 24.2.1 ( 6.6.16 ) and linux-image-edge-rockchip64 with old linux-dtb-current-rockchip64 ( 23.11.1 ) and booted fine without any issue and network working.
When I updated either linux-dtb-current-rockchip64 or linux-dtb-edge-rockchip64 to 24.2.1 and reboot it stops working.
  • Solution
Checking my system:
selu@rock-3a:~$ dd if=/dev/mmcblk0 seek=64 skip=64 count=32704 of=uboot.bin
32704+0 records in
32704+0 records out
16744448 bytes (17 MB, 16 MiB) copied, 0.564798 s, 29.6 MB/s
selu@rock-3a:~$ strings uboot.bin | grep "U-Boot"
U-Boot SPL board init
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt %s
U-Boot SPL 2017.09-armbian (Sep 19 2022 - 14:20:01)
U-Boot
FIT Image with ATF/OP-TEE/U-Boot
U-Boot(64-bit)
*U-Boot
U-Boot dtb
** Invalid partition type "%.32s" (expect "U-Boot")
Enter U-Boot charging mode
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
U-Boot.armv8
MU-Boot EFI: Relocation at %p is out of range (%lx)
U-Boot 2017.09-armbian
## U-Boot bootargs: %s
No valid device tree binary found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb>
U-Boot
Sysmem Error: Failed to reserve sysmem for U-Boot framework
U-Boot 2017.09-armbian (Sep 19 2022 - 14:20:01 +0200)
And this is different from the bundled U-Boot:
selu@rock-3a:~$ strings /usr/lib/linux-u-boot-current-rock-3a/u-boot.itb | grep "U-Boot"
U-Boot(64-bit)
*U-Boot
U-Boot dtb
U-Boot.armv8
U-Boot
U-Boot 2017.09-armbian (May 20 2024 - 00:41:52 +0000)
I could not update U-Boot via armbian-install, somehow my rootfs on NVMe breaks install in the script ( I boot from SD with /boot in it ).
Not detecting the device ( using set -x )
++ sed -e 's/^.*root=//' -e 's/ .*$//'
+ root_uuid=UUID=a0d95135-003b-44d5-8efe-ef62615e7dea
++ blkid
++ tr -d '":'
++ grep UUID=a0d95135-003b-44d5-8efe-ef62615e7dea
++ awk '{print $1}'
+ root_partition=/dev/nvme0n1
++ echo /dev/nvme0n1
++ sed 's/\/dev\///g'
+ root_partition_name=nvme0n1
++ lsblk -ndo pkname /dev/nvme0n1
+ root_partition_device_name=
+ root_partition_device=/dev/
+ exit 1
I crafted a quick n'dirty script:
#!/bin/bash
source /usr/lib/u-boot/platform_install.sh
DIR=/usr/lib/linux-u-boot-current-rock-3a
root_partition_device=/dev/mmcblk0
write_uboot_platform "$DIR" "${root_partition_device}"
And I can confirm that u-boot was updated in SD and now works fine! YEEHAA!
