Jose Luis Posted March 3 Share Posted March 3 (edited) Hi, after upgrading linux-u-boot-rock-3a-current, linux-image-current-rockchip64 and linux-dtb-current-rockchip64 to the 24.2.1 versions, the system losses the network producing kernel errors in dmesg: [ 432.408850] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 432.410880] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 432.410929] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay. [ 432.410954] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30 [ 432.410983] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay. [ 432.411002] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10 [ 432.411051] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 432.411223] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 432.416282] rk_gmac-dwmac fe010000.ethernet: init for RGMII_ID [ 432.417113] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 432.417176] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 432.417205] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 432.417227] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 432.417248] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 432.417268] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 432.417287] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 432.417306] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 432.417336] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 432.417369] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 432.417391] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 432.506616] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 432.569725] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 432.571832] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) I went back to the 23.11.1 versions of the packages and the system has the network back: -rwxr-xr-x 1 root root 319396 Mar 3 10:40 linux-dtb-current-rockchip64_23.11.1_arm64__6.1.63-S69e4-Df461-P59b3-C3542Hfe66-HK01ba-Vc222-B1743-R448a.deb -rwxr-xr-x 1 root root 41712668 Mar 3 10:40 linux-image-current-rockchip64_23.11.1_arm64__6.1.63-S69e4-Df461-P59b3-C3542Hfe66-HK01ba-Vc222-B1743-R448a.deb -rwxr-xr-x 1 root root 1036380 Mar 3 10:40 linux-u-boot-rock-3a-current_23.11.1_arm64__2017.09-Sc559-Pedff-H8c72-Vda90-B1179-R448a.deb Using these packages, this is the output from dmesg: [ 6.259295] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 6.259807] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator [ 6.260113] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 6.260133] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f). [ 6.260147] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26). [ 6.260171] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 6.260276] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 6.274301] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 6.285273] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 6.285315] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 6.285330] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 6.285340] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 6.285349] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 6.285357] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 6.285504] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 6.285518] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 6.285533] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 6.285547] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 6.285558] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 6.360605] spi-nor spi4.0: mx25u12835f (16384 Kbytes) [ 6.599788] rk_gmac-dwmac fe010000.ethernet end0: renamed from eth0 [ 21.045985] rk_gmac-dwmac fe010000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 21.139671] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 21.147558] dwmac4: Master AXI performs any burst length [ 21.147613] rk_gmac-dwmac fe010000.ethernet end0: No Safety Features support found [ 21.147647] rk_gmac-dwmac fe010000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported [ 21.148015] rk_gmac-dwmac fe010000.ethernet end0: registered PTP clock [ 21.155727] rk_gmac-dwmac fe010000.ethernet end0: configuring for phy/rgmii link mode [ 25.295999] rk_gmac-dwmac fe010000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx [ 25.296059] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready Thanks in advance. support.txt dmesg.txt Edited March 3 by Jose Luis 0 Quote Link to comment Share on other sites More sharing options...
