[Armbian build PR] - rk35xx-vendor: add rk3528 and lima driver support
Description
Enable rk3528 soc support to make rk3528 boards bootable. Enable lima gpu driver for mali 400/450 gpu on rk3528 and disable arm mali400/450 driver. Devicetree related change is already in https://github.com/amazingfate/linux-rockchip/commit/419410ff56c8e80b37e100c265d57f23cc0db835
How Has This Been Tested?
  • [x] ./compile.sh kernel BOARD=hinlink-ht2 BRANCH=vendor DEB_COMPRESS=xz KERNEL_CONFIGURE=no
  • [x] Lima gpu driver works on hinlink-ht2
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
