The latest OZPI v.x1 image, the kernel version after the update changed from 6.6.20 to 6.6.16
Hi
I have installed the latest image for Orange Pi Zero v1 https://dl.armbian.com/orangepizero/archive/Armbian_24.2.1_Orangepizero_bookworm_current_6.6.20.img.xz link from https://www.armbian.com/orange-pi-zero/
After the first boot, I see that it is kernel 6.6.20
Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.20-current-sunxi
Linux version 6.6.20-current-sunxi (armbian@next) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Sat Mar  2 17:23:09 UTC 2024
and when I run apt update& apt upgrade
apt list --upgradable
Listing... Done
armbian-firmware/bookworm,bookworm 24.2.1 all [upgradable from: 24.2.1]
linux-image-current-sunxi/bookworm 24.2.1 armhf [upgradable from: 24.2.1]
and when running apt upgrade
apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages will be upgraded:
  armbian-firmware linux-image-current-sunxi
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 111 MB of archives.
After this operation, 42.3 MB disk space will be freed.
Do you want to continue? [Y/n]
Get:1 http://fi.mirror.armbian.de/apt bookworm/main armhf armbian-firmware all 24.2.1 [75.2 MB]
Get:2 http://fi.mirror.armbian.de/apt bookworm/main armhf linux-image-current-sunxi armhf 24.2.1 [35.7 MB]
Fetched 111 MB in 1min 6s (1,678 kB/s)
(Reading database ... 41412 files and directories currently installed.)
Preparing to unpack .../armbian-firmware_24.2.1_all.deb ...
Unpacking armbian-firmware (24.2.1) over (24.2.1) ...
Preparing to unpack .../linux-image-current-sunxi_24.2.1_armhf.deb ...
Armbian 'linux-image-current-sunxi' for '6.6.20-current-sunxi': 'prerm' starting.
Armbian 'linux-image-current-sunxi' for '6.6.20-current-sunxi': 'prerm' finishing.
Armbian 'linux-image-current-sunxi' for '6.6.16-current-sunxi': 'preinst' starting.
Armbian 'linux-image-current-sunxi' for '6.6.16-current-sunxi': 'preinst' finishing.
Unpacking linux-image-current-sunxi (24.2.1) over (24.2.1) ...
Armbian 'linux-image-current-sunxi' for '6.6.20-current-sunxi': 'postrm' starting.
Armbian 'linux-image-current-sunxi' for '6.6.20-current-sunxi': 'postrm' finishing.
Setting up linux-image-current-sunxi (24.2.1) ...
Armbian 'linux-image-current-sunxi' for '6.6.16-current-sunxi': 'postinst' starting.
dkms: autoinstall for kernel 6.6.16-current-sunxi was skipped since the kernel headers for this kernel do not seem to be installed.
update-initramfs: Generating /boot/initrd.img-6.6.16-current-sunxi
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.16-current-sunxi
Image Name:   uInitrd
Created:      Tue Mar 12 07:11:59 2024
Image Type:   ARM Linux RAMDisk Image (gzip compressed)
Data Size:    17410594 Bytes = 17002.53 KiB = 16.60 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.16-current-sunxi to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.6.16-current-sunxi'
update-initramfs: Armbian: done.
Remove unused generated file: /boot/uInitrd-6.6.20-current-sunxi
Remove unused generated file: /boot/initrd.img-6.6.20-current-sunxi
Armbian: update last-installed kernel symlink to 'zImage'...
'/boot/zImage' -> 'vmlinuz-6.6.16-current-sunxi'
Armbian: Debian compat: linux-update-symlinks install 6.6.16-current-sunxi boot/vmlinuz-6.6.16-current-sunxi
I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.16-current-sunxi
I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.16-current-sunxi
I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.16-current-sunxi
I: /initrd.img is now a symlink to boot/initrd.img-6.6.16-current-sunxi
Armbian 'linux-image-current-sunxi' for '6.6.16-current-sunxi': 'postinst' finishing.
Setting up armbian-firmware (24.2.1) ...
After reboot it seems  kernel 6.6.20 was replaced by 6.6.16
Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-sunxi
Linux version 6.6.16-current-sunxi (armbian@next) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Fri Feb 23 08:25:28 UTC 2024
Is that correct?
