[Armbian build PR] - config: boards: add X96 Mate TV Box config
Description
The board has mainline kernel and u-boot support for almost 3 years now but Armbian doesn't build images for it. Add basic build config for this board with Wi-Fi extension enabled. Based on orangepizero2.conf
X96 mate is H616-powered TV Box with the same Wi-Fi/BT chip as OPiZ2 (AW859A). Mainline DT is missing Wi-Fi node and some regulators are disabled, but PR is on its way. It doesn't hurt to add Wi-Fi extension to config now.
How Has This Been Tested?
  • [x] Compile and verify all defined flavours of image on working hardware
  • [X] Tested Wi-Fi extension with patched DT and proved to be working
Checklist:
  • [x] My code follows the style guidelines of this project
  • [x] I have performed a self-review of my own code
  • [x] My changes generate no new warnings
View the full article
