[Armbian build PR] - rockchip: rk3588: edge: fix wrong gpu node patch
Description
As mentioned by @andyshrk , this gpu node patch has deleted line status = "disabled"; of node usb_host2_xhci, this will fix that so usb_host2_xhci will not get enabled on all boards.
How Has This Been Tested?
  • [x] ./compile.sh kernel BOARD=rock-5b BRANCH=edge DEB_COMPRESS=xz KERNEL_GIT=shallow
  • [x] Check node usb_host2_xhci in file cache/sources/linux-kernel-worktree/6.8__rockchip-rk3588__arm64/arch/arm64/boot/dts/rockchip/rk3588s.dtsi
  • [x] rock5b boots fine
Checklist:
Please delete options that are not relevant.
View the full article
