RSS Bot Posted March 29, 2024 Posted March 29, 2024 Description Add support to OrangePi Zero 2W (allwinner H618), changes: Patch for u-boot v2024.04-rc5, includes: allwinner-h616-THS-workaround.patch allwinner-h616-GPU-enable-hack.patch allwinner-pwrled-config-option.patch allwinner-enable-autoboot-keyed.patch allwinner-boot-splash.patch Kernel patch for adding zero2w dts, some part are taken from the orange pi official repo. Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change. Jira reference number [AR-9999] Documentation summary for feature / change Please delete this section if entry to main documentation is not needed. If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer: [ ] short description (copy / paste of PR title) [ ] summary (description relevant for end users) [ ] example of usage (how to see this in function) How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Build and install the current image to SD, and then test on zero2w [x] Build and install the edge image to SD, and then test on zero2w [x] HDMI: test if HDMI output correctly [x] Network: test if wifi connect to access point correctly [x] Uart: test uart0 to get the kernel output [x] USB: test onboard type-c (host) [x] USB: test onboard type-c (otg) [x] USB: test usb port on the 24pin connector [x] GPIO: test GPIO voltage level - pull down and pull up by gpioset, both ok Checklist: Please delete options that are not relevant. [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
