I am trying to accommodate a SIM800 GSM module using UART3 of OP Lite.
For the beginning, just to send a SMS and later on a MMS with a photo taken from gc2035 camera.
This is a source that I made for arduino which works:
  Serial.print("AT+CMGS=");
  Serial.print(char(34)); //before and after phone nr a char (") must be sent
  Serial.print(Phone_nr);
  Serial.println(char(34));
  delay(100);
  Serial.print(message);
  delay(100);
  Serial.println(char(26)); //end of message char
I have set FEX for the UART3 but now I am struggling to start this using system commands, such as:
      echo "AT+CMGS=\r\n" /dev/ttyS3 9600
Any help much aprreciated.
echo -e "+CMGS=\r\n" > /dev/ttyS3
should help.
The 9600 makes no sense though. That is set via stty command.
Thanks, it works :)
One more to go:
GPIO=6
echo $GPIO > /sys/class/gpio/export
echo in > /sys/class/gpio/gpio${GPIO}/direction
while true; do
    if cat /sys/class/gpio/gpio${GPIO}/value;
      then fswebcam -r 640x480 -p YUV420P --jpeg 100 -> image.jpg;
    fi
    sleep 10
done
exit 0
with some reason it executes fswebcam even if cat returns "0".
what could be wrong?
