How do I persist GPIO changes across reboots?
Go to solution Solved by PHLAK,
I have Armbian up and running on a Rock Pi S with a PoE HAT. To enable the audio jack on the PoE HAT I had to run the following commands as mentioned on the official Rock Pi S PoE Hat wiki.
# echo 15 > /sys/class/gpio/export
# echo out > /sys/class/gpio/gpio15/direction
# echo 1 > /sys/class/gpio/gpio15/value
Once enabled, the audio works as needed. However, every time the device is rebooted I have to SSH in and run these commands again to re-enable audio out which is obviously not ideal.
How can I persist these changes between reboots?
  • Solution
I was able to solve this by using systemd-tmpfiles to modify these values on boot. Specifically I created a file `/etc/tmpfiles.d/enable-audio-jack.conf` with the following contents.
w /sys/class/gpio/export - - - - 15
w /sys/class/gpio/gpio15/direction - - - - out
w /sys/class/gpio/gpio15/value - - - - 1
