SD card read-only with Armbian 5.25 or Armbian 5.24
Hi everybody,
I'm trying to install the Armbian_5.25_Lamobo-r1_Debian_jessie_next_4.9.7.img image (or Armbian_5.24_Lamobo-r1_Debian_jessie_4.8.15.img) on my Samsung SD Card EVO+ 32GB (link to amazon)
My BPI-R1 starts properly and I can connect via SSH, this is the result of armbianmonitor -u: http://sprunge.us/PLgf
When I try to upgrade the system (after apt-get update) the filesystem becomes read-only, see the attached file.
Part of kern.log:
Mar  3 16:23:22 localhost kernel: [  296.721494] mmc0: Card stuck in programming state! mmc_do_erase
Mar  3 16:23:23 localhost kernel: [  297.521488] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:24 localhost kernel: [  298.311487] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:24 localhost kernel: [  299.071482] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:24 localhost kernel: [  299.085279] mmc0: tried to reset card, got error -5
Mar  3 16:23:24 localhost kernel: [  299.096769] blk_update_request: I/O error, dev mmcblk0, sector 18227376
Mar  3 16:23:24 localhost kernel: [  299.109988] mmc_erase: group start error -5, status 0x0
Mar  3 16:23:24 localhost kernel: [  299.121645] blk_update_request: I/O error, dev mmcblk0, sector 16791760
Mar  3 16:23:24 localhost kernel: [  299.135010] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:24 localhost kernel: [  299.147297] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:24 localhost kernel: [  299.159445] mmcblk0: error -5 sending status command, aborting
Mar  3 16:23:25 localhost kernel: [  299.951486] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:26 localhost kernel: [  300.741485] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:27 localhost kernel: [  301.501482] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
Mar  3 16:23:27 localhost kernel: [  301.514404] mmc0: tried to reset card, got error -5
Mar  3 16:23:27 localhost kernel: [  301.525191] blk_update_request: I/O error, dev mmcblk0, sector 18227376
Mar  3 16:23:27 localhost kernel: [  301.537944] EXT4-fs (mmcblk0p1): Delayed block allocation failed for inode 57335 at logical offset 0 with max blocks 1 with error 5
Mar  3 16:23:27 localhost kernel: [  301.538078] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:27 localhost kernel: [  301.538084] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:27 localhost kernel: [  301.538089] mmcblk0: error -5 sending status command, aborting
Mar  3 16:23:27 localhost kernel: [  301.538098] blk_update_request: I/O error, dev mmcblk0, sector 16791760
Mar  3 16:23:27 localhost kernel: [  301.538131] blk_update_request: I/O error, dev mmcblk0, sector 16791768
Mar  3 16:23:27 localhost kernel: [  301.538161] blk_update_request: I/O error, dev mmcblk0, sector 16791776
Mar  3 16:23:27 localhost kernel: [  301.538191] blk_update_request: I/O error, dev mmcblk0, sector 16791784
Mar  3 16:23:27 localhost kernel: [  301.538220] blk_update_request: I/O error, dev mmcblk0, sector 16791792
Mar  3 16:23:27 localhost kernel: [  301.538249] blk_update_request: I/O error, dev mmcblk0, sector 16791800
Mar  3 16:23:27 localhost kernel: [  301.538278] blk_update_request: I/O error, dev mmcblk0, sector 16791808
Mar  3 16:23:27 localhost kernel: [  301.541680] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:27 localhost kernel: [  301.541685] mmcblk0: error -5 sending status command, retrying
Mar  3 16:23:27 localhost kernel: [  301.541689] mmcblk0: error -5 sending status command, aborting
[Second test]
I prepared again the SD card and bpi-r1 starts properly; then I tryed to copy a big file (like 7GB) via scp: it worked!!
With the Armbian_5.25_Lamobo-r1_Debian_jessie_default_3.4.113.img image, there are no problems with my Samsung SD Card, after a system upgrade.
I searched in this forum and read the documentation 'Getting started' but I could not find a solution to my problem.
Maybe there is an issue in upgrading the system with 4.8.15 or 4.9.7 image (with my sd card)?
Do you have any suggestions?
Thank you.
apt-get upgrade.txt
I've got the same problem with the Samsung Evo+ SDHC 32Gb on my Banana Pi Pro. According to F3 it's no counterfeit. I verificated the gpg key. I flashed "Armbian_5.25_Bananapipro_Ubuntu_xenial_next_4.9.7" via ether.
When I want to update, it first mentions dpgk:
root@bananapipro:/etc/network# sudo apt-get upgrade
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
I'm following its suggestion:
root@bananapipro:/etc/network# sudo dpkg --configure -a
Setting up libnettle6:armhf (3.2-1ubuntu0.16.04.1) ...
Setting up libisc160:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up libisc-export160 (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up libnm0:armhf (1.2.2-0ubuntu0.16.04.4) ...
Setting up libdns-export162 (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up libhogweed4:armhf (3.2-1ubuntu0.16.04.1) ...
Setting up libisccc140:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Processing triggers for libc-bin (2.23-0ubuntu5) ...
Setting up liblwres141:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up libdns162:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up libisccfg140:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up libbind9-140:armhf (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up bind9-host (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Setting up dnsutils (1:9.10.3.dfsg.P4-8ubuntu1.5) ...
Over HDMI i see exactly the same code as theroot posted above due to the Read-only Filesystem.
Looking at dmesg:
[ 1100.164087] mmc0: Card stuck in programming state! mmc_do_erase
[ 1100.964095] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1101.764100] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1102.534118] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1102.550106] mmc0: tried to reset card, got error -5
[ 1102.550122] blk_update_request: I/O error, dev mmcblk0, sector 2088736
[ 1102.566000] mmcblk0: error -5 sending status command, retrying
[ 1102.580920] mmcblk0: error -5 sending status command, retrying
[ 1102.595742] mmcblk0: error -5 sending status command, aborting
[ 1103.384140] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1104.174150] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1104.934171] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1104.949897] mmc0: tried to reset card, got error -5
[ 1104.949912] blk_update_request: I/O error, dev mmcblk0, sector 2817248
[ 1104.965287] blk_update_request: I/O error, dev mmcblk0, sector 2817256
[ 1104.980437] blk_update_request: I/O error, dev mmcblk0, sector 2817264
[ 1104.995491] blk_update_request: I/O error, dev mmcblk0, sector 2817272
[ 1105.010395] blk_update_request: I/O error, dev mmcblk0, sector 2817280
[ 1105.025265] blk_update_request: I/O error, dev mmcblk0, sector 2817288
[ 1105.040014] blk_update_request: I/O error, dev mmcblk0, sector 2817296
[ 1105.054755] blk_update_request: I/O error, dev mmcblk0, sector 2817304
[ 1105.069349] blk_update_request: I/O error, dev mmcblk0, sector 2817312
[ 1105.084021] mmcblk0: error -5 sending status command, retrying
[ 1105.097886] mmcblk0: error -5 sending status command, retrying
[ 1105.111614] mmcblk0: error -5 sending status command, aborting
[ 1105.904196] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1106.694208] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1107.454226] sunxi-mmc 1c0f000.mmc: fatal err update clk timeout
[ 1107.468835] mmc0: tried to reset card, got error -5
[ 1107.468919] EXT4-fs (mmcblk0p1): Delayed block allocation failed for inode 57349 at logical offset 0 with max blocks 8 with error 5
[ 1107.488787] EXT4-fs (mmcblk0p1): This should not happen!! Data will be lost
[ 1107.530227] mmcblk0: error -5 sending status command, retrying
[ 1107.546817] mmcblk0: error -5 sending status command, retrying
[ 1107.563234] mmcblk0: error -5 sending status command, aborting
[ 1107.579520] blk_update_request: 31 callbacks suppressed
[ 1107.579530] blk_update_request: I/O error, dev mmcblk0, sector 2973024
[ 1107.596615] blk_update_request: I/O error, dev mmcblk0, sector 2973032
[ 1107.613710] blk_update_request: I/O error, dev mmcblk0, sector 2973040
[ 1107.630835] blk_update_request: I/O error, dev mmcblk0, sector 2973048
[ 1107.647854] blk_update_request: I/O error, dev mmcblk0, sector 2973056
[ 1107.664677] blk_update_request: I/O error, dev mmcblk0, sector 2973064
[ 1107.681485] blk_update_request: I/O error, dev mmcblk0, sector 2973072
[ 1107.698232] blk_update_request: I/O error, dev mmcblk0, sector 2973080
[ 1107.714855] blk_update_request: I/O error, dev mmcblk0, sector 2973088
[ 1107.731267] blk_update_request: I/O error, dev mmcblk0, sector 2973096
[ 1107.747595] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:314: I/O error -5 writing to inode 57350 (offset 0 size 155648 starting block 371666)
[ 1107.747613] Buffer I/O error on device mmcblk0p1, logical block 371372
[ 1107.763737] Buffer I/O error on device mmcblk0p1, logical block 371373
[ 1107.779459] Buffer I/O error on device mmcblk0p1, logical block 371374
[ 1107.794574] Buffer I/O error on device mmcblk0p1, logical block 371375
[ 1107.809618] Buffer I/O error on device mmcblk0p1, logical block 371376
[ 1107.824522] Buffer I/O error on device mmcblk0p1, logical block 371377
[ 1107.839237] Buffer I/O error on device mmcblk0p1, logical block 371378
[ 1107.853658] Buffer I/O error on device mmcblk0p1, logical block 371379
[ 1107.868000] Buffer I/O error on device mmcblk0p1, logical block 371380
[ 1107.882142] Buffer I/O error on device mmcblk0p1, logical block 371381
[ 1107.896348] mmcblk0: error -5 sending status command, retrying
[ 1107.908082] mmcblk0: error -5 sending status command, retrying
[ 1107.919633] mmcblk0: error -5 sending status command, aborting
[ 1107.931153] EXT4-fs error (device mmcblk0p1): ext4_find_entry:1463: inode #1878: comm dpkg: reading directory lblock 0
[ 1107.947724] mmcblk0: error -5 sending status command, retrying
[ 1107.959213] mmcblk0: error -5 sending status command, retrying
[ 1107.970646] mmcblk0: error -5 sending status command, aborting
[ 1107.981886] Buffer I/O error on dev mmcblk0p1, logical block 0, lost sync page write
[ 1107.995211] Aborting journal on device mmcblk0p1-8.
[ 1108.005935] mmcblk0: error -5 sending status command, retrying
[ 1108.017226] mmcblk0: error -5 sending status command, retrying
[ 1108.028205] mmcblk0: error -5 sending status command, aborting
[ 1108.039054] Buffer I/O error on dev mmcblk0p1, logical block 131072, lost sync page write
[ 1108.052323] JBD2: Error -5 detected when updating journal superblock for mmcblk0p1-8.
[ 1108.065228] EXT4-fs (mmcblk0p1): Remounting filesystem read-only
According to this post my file system ext4 is broken.
------------- Solved? -------------
Using my user account instead of root solved my problem.
Seems that upgrading console-setup-linux is causing a problem when running "sudo apt-get upgrade":
Unpacking console-setup-linux (1.108ubuntu15.3) over (1.108ubuntu15.2) ...
dpkg: error processing archive /var/cache/apt/archives/console-setup-linux_1.108ubuntu15.3_all.deb (--unpack):
 unable to sync file '/lib/systemd/system/setvtrgb.service.dpkg-new': Input/output error
