[Fixed] iwlwifi broke with recent upgrade 6.1.43-vendor-rk35xx
Go to solution Solved by specs,
Current kernel:
Linux rock-5b 6.1.43-vendor-rk35xx #1 SMP Mon Mar 18 05:06:52 UTC 2024 aarch64 GNU/Linux
Symptoms:
$ lspci
0002:20:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01)
0002:21:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01)
0004:41:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
And after a reboot I find with dmesg:
# modprobe iwlwifi
modprobe: ERROR: could not insert 'iwlwifi': Exec format error
root@rock-5b:~# dmesg|grep -E -A 3 -B 3 "intel|iwl"
[    6.285747] input_leds: disagrees about version of symbol module_layout
[    6.288159] joydev: disagrees about version of symbol module_layout
[    6.309378] gpu_sched: disagrees about version of symbol module_layout
[    6.314006] btintel: disagrees about version of symbol module_layout
[    6.314148] btintel: disagrees about version of symbol module_layout
[    6.314693] btintel: disagrees about version of symbol module_layout
[    6.314751] btintel: disagrees about version of symbol module_layout
[    6.368536] iwlwifi: disagrees about version of symbol module_layout
[    6.377085] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    6.378547] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    6.380075] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    6.380564] btintel: disagrees about version of symbol module_layout
[    6.381271] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    6.383701] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    6.384399] dm_mod: disagrees about version of symbol module_layout
[  217.993684] [drm:vop2_plane_atomic_check] *ERROR* Invalid size: 64x1->64x1, min size is 4x4
[  218.001798] [drm:vop2_plane_atomic_check] *ERROR* Invalid size: 64x1->64x1, min size is 4x4
[  218.009720] [drm:vop2_plane_atomic_check] *ERROR* Invalid size: 64x1->64x1, min size is 4x4
[  439.786500] iwlwifi: disagrees about version of symbol module_layout
[  445.011474] iwlwifi: disagrees about version of symbol module_layout
[  476.290795] iwlwifi: disagrees about version of symbol module_layout
Manually installing the iwlwifi driver yields:
# modprobe iwlwifi
Perhaps more people ran into the same problem?
Of course I ran into this problem while quickly trying to access some server, only finding that the wifi adapter was not working anymore ("it used to work").
The quick & dirty solution was finding a cable bypassing wifi.
Edited by specs
  • specs changed the title to [Fixed] iwlwifi broke with recent upgrade 6.1.43-vendor-rk35xx
  • Solution
Finally found the problem:
Since the kernel was half installed, the kernel and the modules did not match. This means all the modules did not work.
Manually remounting the /boot partition and reinstalling the kernel did the trick.
There is still some detail that the "uname -a" and "cat /proc/version" are not updated, although the kernel was replaced.
Edited by specs
