Hi all.
I've got an issue trying to use Bluetooth and RFCOMM.
My system is:
Cubieboard2 running latest img and updated with apt-get update/upgrade:
  ____      _     _      _                         _   ____
 / ___|   _| |__ (_) ___| |__   ___   __ _ _ __ __| | |___ \
| |  | | | | '_ \| |/ _ \ '_ \ / _ \ / _` | '__/ _` |   __) |
| |__| |_| | |_) | |  __/ |_) | (_) | (_| | | | (_| |  / __/
 \____\__,_|_.__/|_|\___|_.__/ \___/ \__,_|_|  \__,_| |_____|
Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 4.9.12-sunxi
System load:   0.07            	Up time:       30 min
Memory usage:  7 % of 1001Mb 	IP:            192.168.1.108
CPU temp:      33°C
Usage of /:    34% of 7.2G
Last login: Sun Mar 12 15:08:57 2017 from 192.168.1.103
root@cubieboard2:~# uname -a
Linux cubieboard2 4.9.12-sunxi #4 SMP Thu Feb 23 19:46:51 CET 2017 armv7l GNU/Linux
When I plug the Bluetooth USB dongle I get following dmesg:
root@cubieboard2:~# dmesg -c
[  102.456773] usb 4-1: new full-speed USB device number 2 using ohci-platform
[  102.726860] usb 4-1: New USB device found, idVendor=1131, idProduct=1004
[  102.726883] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  102.726893] usb 4-1: Product: ISSCEDRBTA
[  102.726903] usb 4-1: Manufacturer: ISSC
[  102.809982] Bluetooth: Core ver 2.22
[  102.810123] NET: Registered protocol family 31
[  102.810130] Bluetooth: HCI device and connection manager initialized
[  102.810158] Bluetooth: HCI socket layer initialized
[  102.810175] Bluetooth: L2CAP socket layer initialized
[  102.810269] Bluetooth: SCO socket layer initialized
[  102.852031] usbcore: registered new interface driver btusb
[  103.285771] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  103.285785] Bluetooth: BNEP filters: protocol multicast
[  103.285806] Bluetooth: BNEP socket layer initialized
root@cubieboard2:~# lsmod
bnep                    8221  2
btusb                  21996  0
btrtl                   3731  1 btusb
btbcm                   4867  1 btusb
btintel                 5439  1 btusb
bluetooth             247916  24 btrtl,btintel,bnep,btbcm,btusb
cfg80211              337391  0
rfkill                  8383  3 bluetooth,cfg80211
sun4i_codec            10104  3
evdev                   9412  1
snd_soc_core           97876  1 sun4i_codec
snd_pcm_dmaengine       2770  1 snd_soc_core
snd_pcm                57757  2 snd_pcm_dmaengine,snd_soc_core
nvmem_sunxi_sid         1967  0
ir_lirc_codec           4088  0
snd_timer              14809  1 snd_pcm
nvmem_core              7158  1 nvmem_sunxi_sid
lirc_dev                6245  1 ir_lirc_codec
snd                    35783  3 snd_timer,snd_soc_core,snd_pcm
soundcore                858  1 snd
sun4i_ts                3414  0
sunxi_cir               3159  0
sun4i_ss               13213  0
cpufreq_dt              2920  0
uio_pdrv_genirq         2780  0
uio                     6272  1 uio_pdrv_genirq
bonding                82855  0
fuse                   62841  1
root@cubieboard2:~# hciconfig -a
hci0:	Type: BR/EDR  Bus: USB
	BD Address: 00:15:83:E3:4B:90  ACL MTU: 510:8  SCO MTU: 48:10
	UP RUNNING
	RX bytes:541 acl:0 sco:0 events:28 errors:0
	TX bytes:1333 acl:0 sco:0 commands:28 errors:0
	Features: 0xff 0xfe 0xff 0xfe 0x98 0x3f 0x79 0x83
	Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
	Link policy: RSWITCH HOLD SNIFF
	Link mode: SLAVE ACCEPT
	Class: 0x000000
	Service Classes: Unspecified
	Device Class: Miscellaneous,
	HCI Version: 2.1 (0x4)  Revision: 0x90e
	LMP Version: 2.1 (0x4)  Subversion: 0x316
	Manufacturer: Integrated System Solution Corp. (57)
PS: how you can see with lsmod result the RFCOMM module isn't yet loaded.
So BT dongle is working and I can find the desired a near powered HC - 05 Bluetooth Serial Module:
root@cubieboard2:~# hcitool scan
Scanning ...
	30:14:12:26:06:04	IQ021-0006
root@cubieboard2:~# hcitool info 30:14:12:26:06:04
Requesting information ...
	BD Address:  30:14:12:26:06:04
	Device Name: IQ021-0006
	LMP Version: 2.1 (0x4) LMP Subversion: 0x1735
	Manufacturer: Cambridge Silicon Radio (10)
	Features: 0xff 0xff 0x8f 0xfe 0x9b 0xff 0x59 0x83
		<3-slot packets> <5-slot packets> <encryption> <slot offset>
		<timing accuracy> <role switch> <hold mode> <sniff mode>
		<park state> <RSSI> <channel quality> <SCO link> <HV2 packets>
		<HV3 packets> <u-law log> <A-law log> <CVSD> <paging scheme>
		<power control> <transparent SCO> <broadcast encrypt>
		<EDR ACL 2 Mbps> <EDR ACL 3 Mbps> <enhanced iscan>
		<interlaced iscan> <interlaced pscan> <inquiry with RSSI>
		<extended SCO> <EV4 packets> <EV5 packets> <AFH cap. slave>
		<AFH class. slave> <3-slot EDR ACL> <5-slot EDR ACL>
		<sniff subrating> <pause encryption> <AFH cap. master>
		<AFH class. master> <EDR eSCO 2 Mbps> <EDR eSCO 3 Mbps>
		<3-slot EDR eSCO> <extended inquiry> <simple pairing>
		<encapsulated PDU> <non-flush flag> <LSTO> <inquiry TX power>
		<extended features>
HC-05 has a default PIN number of 1234 for authentication so I've added right info in pincodes file
root@cubieboard2:/# echo "30:14:12:26:06:04 1234" >> /var/lib/bluetooth/00\:15\:83\:E3\:4B\:90/pincodes
At this point I try to bind and connect HC-05 with RFCOMM module to get /dev/rfcomm0:
root@cubieboard2:/# rfcomm -a
root@cubieboard2:/# ls -p /dev/rfc*
ls: cannot access /dev/rfc*: No such file or directory
root@cubieboard2:/# rfcomm bind rfcomm0 30:14:12:26:06:04 1
rfcomm0: 30:14:12:26:06:04 channel 1 clean
/dev/rfcomm0
root@cubieboard2:/# lsmod
rfcomm                 25714  1
bnep                    8221  2
btusb                  21996  0
btrtl                   3731  1 btusb
btbcm                   4867  1 btusb
bluetooth             247916  27 btrtl,btintel,bnep,btbcm,rfcomm,btusb
cfg80211              337391  0
sun4i_codec            10104  3
evdev                   9412  1
soundcore                858  1 snd
sun4i_ts                3414  0
sunxi_cir               3159  0
sun4i_ss               13213  0
cpufreq_dt              2920  0
bonding                82855  0
fuse                   62841  1
root@cubieboard2:/# dmesg -c
[ 1088.424557] Bluetooth: RFCOMM TTY layer initialized
[ 1088.424601] Bluetooth: RFCOMM socket layer initialized
[ 1088.424637] Bluetooth: RFCOMM ver 1.11
/dev/rfcomm0 now exist and RFCOMM module is loaded by bluetooth module.
At this point I try to send some chars to HC-05 using screen with #screen /dev/rfcomm0 but
screen exit just after one second killing screen program.
Same thing if I use picocom:
root@cubieboard2:/# picocom -b 9600 /dev/rfcomm0
picocom v1.7
port is        : /dev/rfcomm0
flowcontrol    : none
baudrate is    : 9600
parity is      : none
databits are   : 8
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Terminal ready
FATAL: term closed
Some ideas ?
Thank you very much in advance !!!
Silverio Diquigiovanni
I've tried same thing on PC and after bind to rfcomm0 the GUI present a request for PIN code...
Seems that /var/lib/bluetooth/xx:xx:xx:xx:xx/pairing file method don't works so in a CLI system PIN code can't be entered :(
I've tried with bluetoothhctl agent to pair the USB dongle:
root@cubieboard2:/# bluetoothctl
[NEW] Controller 00:15:83:E3:4B:90 cubieboard2 [default]
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# scan on
Discovery started
[CHG] Controller 00:15:83:E3:4B:90 Discovering: yes
[NEW] Device 30:14:12:26:06:04 IQ021-0006
[bluetooth]# agent on
Agent registered
[bluetooth]# pair 30:14:12:26:06:04
Attempting to pair with 30:14:12:26:06:04
[CHG] Device 30:14:12:26:06:04 Connected: yes
Request PIN code
[agent] Enter PIN code: 1234
[CHG] Device 30:14:12:26:06:04 UUIDs:
	00001101-0000-1000-8000-00805f9b34fb
[CHG] Device 30:14:12:26:06:04 Paired: yes
Pairing successful
[CHG] Device 30:14:12:26:06:04 Connected: no
[bluetooth]# quit
Agent unregistered
[DEL] Controller 00:15:83:E3:4B:90 cubieboard2 [default]
picocom v1.7
flowcontrol    : none
baudrate is    : 9600
parity is      : none
databits are   : 8
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
imap is        :
omap is        :
Terminal ready
Now system connect fine to /dev/rfcomm0
If someone know a NON interactive way to insert pairing PIN code I will be very happy.
Mine is a system without any user interface where a user attach its USB dongle and must get access to rfcommxx
just after plug.
Thank you very much for suggestions !!!
