I tried to use the Legacy 3.4.113 but when it loads the kernel the Cubieboard2 shows a weird scrambeled picture on the Monitor and just shuts down. So I decided to build the kernel from source.
I'm pretty new to Armbian, and the compile script is a lot of different. I built the kernel using the compile.sh script for Cubieborad2.
I installed the Mainline 4.9.7 Armbian on Cubieboard2. My question is how to install the built kernel (3.x) on the existing system, as if I try to install the debs I get that I can't install over existing firmware and u-boot (even with force-install)?
Thanks!
