pmartin Posted March 19, 2017 Posted March 19, 2017 I am trying to install perf on armbian. It happens that perf is dependent on the kernel release (see /usr/bin/perf, a shell script). I use kernel 4.10.0-sun8i, but the linux-tools installed are apparently for kernel 3.16: # uname -r 4.10.0-sun8i # apt-get install linux-tools Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: libdw1 libperl5.20 libpython2.7 linux-tools-3.16 Suggested packages: linux-doc-3.16 The following NEW packages will be installed: libdw1 libperl5.20 libpython2.7 linux-tools linux-tools-3.16 0 upgraded, 5 newly installed, 0 to remove and 1 not upgraded. [...] # /usr/bin/perf /usr/bin/perf: line 24: exec: perf_4.10: not found E: linux-tools-4.10 is not installed. Is a linux-tools package available for kernel 4.10? Thanks. Pascal.
James Kingdon Posted June 27, 2017 Posted June 27, 2017 I've run in to the same problem, and I've not yet been able to get perf running on any of my boards. I was thinking of pulling the sources and compiling it locally. I'd be interested to hear if anyone has already solved the problem! Edit: I had a go at compiling perf for the NanoPi M3 this evening. I realised I already had the source included in the download for the kernel, in tools/perf. Cross compiling seemed to get bogged down with dependencies, so I ended up copying the entire linux source tree to the M3 and compiling perf there. cd into the tools/perf directory and type make. I still ran into several dependency issues (lex, yacc, bison and others), but I just installed them one by one and tried again. I couldn't find python-config so I ignored that - it doesn't seem to be needed for core functionality. sudo make DESTDIR=/usr install annoyingly recompiles everything again, but I ended up with a working perf command. There's also a 'make install-man' target, but it has a dependency on asciidoc, and trying to install that has sent apt into a frenzy of downloading a couple of Gigs of stuff! Still, it's nice to have a working perf, even if not all the stats I'm used to on x86 are available.
