[Armbian build PR] - armsom rk3588 boards: use radxa's new uboot
Description
Use radxa's next-dev-v2024.03 branch for armsom's boards. Note that I have to remove CONFIG_OPTEE_ALWAYS_USE_SECURITY_PARTITION=y from defconfig to boot the board. So boards affected by https://github.com/armbian/build/pull/6534 like nanopi6 and nanopc-t6 should also check this. @efectn @Tonymac32
How Has This Been Tested?
  • [x] ./compile.sh BOARD=armsom-sige7 BRANCH=vendor BUILD_DESKTOP=no BUILD_MINIMAL=no DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=bookworm KERNEL_GIT=shallow
Checklist:
Please delete options that are not relevant.
View the full article
