[Armbian build PR] - bcm2711: Use FS UUID and write config.txt and cmdline.txt earlier
Description
This PR makes two changes for the bcm2711 family:
  1. Use FS UUID for mounting the root filesystem instead of the FS label, bringing this family in line with most other boards.
  2. Write config.txt and cmdline.txt earlier, allowing it to be modified from customize-image-host.sh or customize-image.sh.
These two changes are conceptually independent, but touch the same area of code, so I put them in a single PR instead of splitting them.
Documentation summary for feature / change
No documentation needed.
How Has This Been Tested?
  • Built for rpi4b, with customizations to cmdline.txt and config.txt in customize-image-host.sh. Tested on rpi3b+ board.
  • I do not have a rpi5 to test with, but I expect no issues there.
Checklist:
Please delete options that are not relevant.
  • [x] I have commented my code, particularly in hard-to-understand areas
View the full article
