RSS Bot Posted April 4 Share Posted April 4 This skips all git checkout, patching, configuring and cleaning when USE_EXISTING_KERNEL_TREE=yes is passed. This can be useful when doing kernel development by making changes directly to the kernel sourcetree in cache/sources, while still allowing to use the compile.sh to use the same compilation commands, deb package building, ccache, etc. It is also useful when bisecting a kernel issue. Can be used something like this: USE_EXISTING_KERNEL_TREE=yes ./compile.sh default kernel To produce a kernel deb in a few minutes ready to be installed on a device. This is mostly a proof of concept to explore the usecase. In particular: I am not happy with the USE_EXISTING_KERNEL_TREE name yet. I wonder if this variable should maybe be split into different ones (e.g. for skipping git checkout, patching, config, clean already has one that can be used). Or maybe it would be better to split off some code out of compile_kernel() and expose a kernel_build and/or kernel_package command from ./compile.sh instead? View the full article Link to comment Share on other sites More sharing options...
