KDE Neon for Armbian: Missing a Key Component? Or Simply well hid?
Go to solution Solved by bedna,
Hi all,
I decided today to give an Armbian build a whirl as a virtual machine (guest). In particular, Armbian_24.2.4_Uefi-x86_jammy_current_6.6.21_kde-neon_desktop.img.
As is usual with installing a virtual machine, it comes up with a default video resolution of 1024x768; I can usually quickly get it full screen on my system as 1920x1080 by going to the System Settings : Hardware : Display and Monitor : etc.
However, here there is no hardware subsection at all, and a search didn't turn up a setting to change the display.
Any advice on where to find it? I installed the spice guest driver and related packages on the guest.
Thanks!
  • Solution
I do not know what software you use to create the virtual machine, but this is question for them to answer.
