[Armbian build PR] - Fix memory size detection for 1.5GB Orange Pi Zero 3 board on v2024.01 u-boot release
Description
This is to fix wrong DRAM size detection in Orange Pi Zero 3 board with 1.5GB DRAM. Currently they are not able to boot as they detect 2GB DRAM, so after applying this patch they will boot normally. Other boards with 1GB/2GB/4GB DRAM will continue working the same way with this patch.
This patch would only be applied to u-boot v2024.01 release. I will provide other patch for u-boot v2024.04 and newer.
How Has This Been Tested?
  • [X] Build image for Orange Pi Zero 3 board, flash devices with 1/1.5/2/4GB DRAM and power on with serial cable: logs will show the right memory size
  • [X] Build image for Orange Pi Zero 3 board, flash devices with 1/1.5/2/4GB DRAM and power on: boards will boot normally
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [X] I have commented my code, particularly in hard-to-understand areas
  • [X] My changes generate no new warnings
View the full article
