[Armbian build PR] - Change the way repository is getting updated
Description
This speed up the process of rebuilding repository as we eos repositories are served as empty.
Closing https://github.com/armbian/build/issues/6561
How Has This Been Tested?
  • [x] Manual repository generation
Cleanup: dropping unsupported
Removing output/repository/public/dists/buster...
Removing output/repository/public/pool/buster-desktop...
Removing output/repository/public/pool/buster-utils...
Cleaning up prefix "." components main...
Published repository has been removed successfully.
Removing output/repository/public/dists/focal...
Removing output/repository/public/pool/focal-desktop...
Removing output/repository/public/pool/focal-utils...
Removing output/repository/public/dists/kinetic...
Removing output/repository/public/pool/kinetic-desktop...
Removing output/repository/public/pool/kinetic-utils...
Removing output/repository/public/dists/lunar...
Removing output/repository/public/pool/lunar-desktop...
Removing output/repository/public/pool/lunar-utils...
Adding: bookworm
Publishing: bookworm
Adding: bullseye
Publishing: bullseye
Publishing: buster
Publishing: focal
Adding: jammy
Publishing: jammy
Publishing: kinetic
Publishing: lunar
Adding: mantic
Publishing: mantic
Adding: noble
Publishing: noble
Adding: sid
Publishing: sid
Adding: trixie
Publishing: trixie
 * [bookworm-desktop]: Armbian bookworm desktop (packages: 0)
 * [bookworm-utils]: Armbian bookworm utilities (packages: 0)
 * [bookworm]: Armbian main repository (packages: 0)
 * [bullseye-desktop]: Armbian bullseye desktop (packages: 0)
 * [bullseye-utils]: Armbian bullseye utilities (packages: 0)
 * [bullseye]: Armbian main repository (packages: 0)
 * [buster-desktop]: Armbian buster desktop (packages: 0)
 * [buster-utils]: Armbian buster utilities (packages: 0)
 * [buster]: Armbian main repository (packages: 0)
 * [focal-desktop]: Armbian focal desktop (packages: 0)
 * [focal-utils]: Armbian focal utilities (packages: 0)
 * [focal]: Armbian main repository (packages: 0)
 * [jammy-desktop]: Armbian jammy desktop (packages: 0)
 * [jammy-utils]: Armbian jammy utilities (packages: 0)
 * [jammy]: Armbian main repository (packages: 0)
 * [kinetic-desktop]: Armbian kinetic desktop (packages: 0)
 * [kinetic-utils]: Armbian kinetic utilities (packages: 0)
 * [kinetic]: Armbian main repository (packages: 0)
 * [lunar-desktop]: Armbian lunar desktop (packages: 0)
 * [lunar-utils]: Armbian lunar utilities (packages: 0)
 * [lunar]: Armbian main repository (packages: 0)
 * [mantic-desktop]: Armbian mantic desktop (packages: 0)
 * [mantic-utils]: Armbian mantic utilities (packages: 0)
 * [mantic]: Armbian main repository (packages: 0)
 * [noble-desktop]: Armbian noble desktop (packages: 0)
 * [noble-utils]: Armbian noble utilities (packages: 0)
 * [noble]: Armbian main repository (packages: 0)
 * [oracular-desktop]: Armbian oracular desktop (packages: 0)
 * [oracular-utils]: Armbian oracular utilities (packages: 0)
 * [oracular]: Armbian main repository (packages: 0)
 * [sid-desktop]: Armbian sid desktop (packages: 0)
 * [sid-utils]: Armbian sid utilities (packages: 0)
 * [sid]: Armbian main repository (packages: 0)
 * [trixie-desktop]: Armbian trixie desktop (packages: 0)
 * [trixie-utils]: Armbian trixie utilities (packages: 0)
 * [trixie]: Armbian main repository (packages: 0)
Checklist:
View the full article
