[Armbian build PR] - rk35xx-vendor: enable AHCI_DWC for rk3568 sata
Description
The vendor config of rk35xx is originally for rk3588 which doesn't need this driver. But rk3568 need it. CONFIG_NET_VENDOR_MOTORCOMM=y is introduced by rewrite-kernel-config, I guess it should be fine.
How Has This Been Tested?
  • [x] ./compile.sh BOARD=hinlink-hnas BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=yes DEB_COMPRESS=xz KERNEL_CONFIGURE=no RELEASE=jammy KERNEL_GIT=shallow
  • [x] Tested on hinlink hnas which has 4 2.5 inch sata.
Checklist:
Please delete options that are not relevant.
View the full article
