[Armbian build PR] - build(deps): bump ossf/scorecard-action from 2.3.1 to 2.3.3
Bumps ossf/scorecard-action from 2.3.1 to 2.3.3.
Release notes
Sourced from ossf/scorecard-action's releases.
v2.3.3
[!NOTE]
There is no v2.3.2 release as a step was skipped in the release process. This was fixed and re-released under the v2.3.3 tag
What's Changed
For a full changelist of what these include, see the v5.0.0-rc1 and v5.0.0-rc2 release notes.
Documentation
Full Changelog: https://github.com/ossf/scorecard-action/compare/v2.3.1...v2.3.3
Commits
  • dc50aa9 :seedling: Bump docker tag for v2.3.3 release (#1368)
  • 8ff5700 :seedling: Bump github.com/ossf/scorecard/v5 from v5.0.0-rc2 to v5.0.0-rc2.0....
  • 8ba5e73 update api links to new scorecard.dev site (#1376)
  • 92ddde3 Bump github.com/ossf/scorecard/v5 from v5.0.0-rc1 to v5.0.0-rc2 (#1374)
  • 6c55905 :seedling: Bump golang.org/x/net from 0.24.0 to 0.25.0 (#1373)
  • 09bb953 :seedling: Bump distroless/base in the docker-images group (#1372)
  • 1511e13 :seedling: Bump the github-actions group across 1 directory with 6 updates (#...
  • df66cd8 :seedling: Bump the docker-images group with 2 updates (#1370)
  • fad9a3c :seedling: Bump distroless/base in the docker-images group (#1364)
  • 1e01a30 :seedling: Bump the github-actions group with 3 updates (#1365)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
