[Armbian build PR] - rk-multimedia-amazingfate: add noble support
Description
Ubuntu noble is released and I just updated rk multimedia packages for it: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia/+packages?field.name_filter=&field.status_filter=published&field.series_filter=noble
widevine package is renamed to libwidevinecdm0 because I borrow it from raspberypi: https://archive.raspberrypi.org/debian/pool/main/w/widevine/. It does not work at the moment but I don't want to get back to jammy's one which has to patch glibc.
How Has This Been Tested?
  • [x] ./compile.sh BOARD=rock-5b BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DEB_COMPRESS=xz DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=noble ENABLE_EXTENSIONS="rk-panthor mesa-oibaf rk-multimedia-amazingfate"
  • [x] chromium-browser v114 should have mpp support with arg --ozone-platform=wayland --use-gl=egl
Checklist:
Please delete options that are not relevant.
View the full article
