[Armbian build PR] - fixed Tinker-edge-r gpu bug
Description
Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change.
Jira reference number [AR-9999]
Documentation summary for feature / change
Please delete this section if entry to main documentation is not needed.
If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer:
  • [x] short description (copy / paste of PR title)
  • [x] summary (description relevant for end users)
  • [x] example of usage (how to see this in function)
How Has This Been Tested?
  • [ ] Test A
  • [ ] Test B
Checklist:
Please delete options that are not relevant.
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] My changes generate no new warnings
View the full article
