[Armbian build PR] - [WIP] Fix issue #6528 opi-zero2w, ethernet PHY not powered
Description
Add some patches to fix the ethernet PHY on orangepi zero2w, includes:
Jira reference number [AR-9999]
Documentation summary for feature / change
Please delete this section if entry to main documentation is not needed.
If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer:
  • [ ] short description (copy / paste of PR title)
  • [ ] summary (description relevant for end users)
  • [ ] example of usage (how to see this in function)
How Has This Been Tested?
  • [ ] Test A
  • [ ] Test B
Checklist:
Please delete options that are not relevant.
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] My changes generate no new warnings
View the full article
