[Armbian build PR] - rockchip-rk3588: drop BOOTFS_TYPE for single root partition image
Description
I guess all these BOOTFS_TYPE come from https://github.com/armbian/build/pull/3874. Rock3a and other rk356x boards uses an old version of vendor u-boot: https://github.com/radxa/u-boot/tree/stable-4.19-rock3, which has bad support for ext4 filesystem. While rk3588 uses new version of vendor u-boot which doesn't have ext4 partition issue, so I just drop all this config from rk3588 boards. Command to query boards with this config:
grep -rn rockchip-rk3588 config/boards/|awk -F ':' '{print $1}'|xargs grep BOOTFS_TYPE
Here are the vendor uboot source of these boards:
board vendor uboot source
armsom-sige7 armsom-w3 nanopc-cm3588-nas nanopct6 nanopi-r6s rock-5b https://github.com/radxa/u-boot/tree/next-dev-v2024.03
fxblox-rk1 https://github.com/functionland/u-boot/tree/next-dev
indiedroid-nova https://github.com/stvhay/u-boot/tree/rockchip-rk3588-unified
orangepi5-plus orangepi5pro https://github.com/orangepi-xunlong/u-boot-orangepi/tree/v2017.09-rk3588
orangepi5 https://github.com/u-boot/u-boot/tree/2f0282922b2c458eea7f85c500a948a587437b63
How Has This Been Tested?
  • [x] ./compile.sh build BOARD=rock-5b BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DEB_COMPRESS=xz DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base ENABLE_EXTENSIONS='rk-panthor mesa-oibaf rk-multimedia-amazingfate' KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=noble
Checklist:
Please delete options that are not relevant.
View the full article
