[Armbian build PR] - Add doas support to `is_root_or_sudo_prefix`
Description
doas is not compatible with sudo flags. The codebase was checked for sudo-specific uses of this function, but none were found, all cases were in the form of sudo <command>. Replacing it with doas <command> yields the same result.
Was extracted from #6576 and can't be merged until it's reverted in #6642
How Has This Been Tested?
Used to build images on my machine with extensions that use is_root_or_sudo_prefix
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
View the full article
