IgorS Posted April 8, 2017 Posted April 8, 2017 In case that somebody need such thing: Armbian legacy stable installed on SD card. Moved to emmc with sudo nand-sata-install. Boot from emmc works good when sd is not plugged. uname -a: Linux orangepiplus2e 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l armv7l armv7l GNU/Linux Then I pluged sd while system running, erase SD with: sudo dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=1000 (be careful at this step, use lsblk to detect actual name for sd) Then I created partition on it and formated it to ext4 fs using GParted. I become sytem which boots from emmc, despite inserted sd card. Also, added it to fstab to automount it if is plugged at boot time: UUID=f45729ff-0cd2-40cc-bb98-dff1e954f940 /mnt/data ext4 nofail,auto,noatime,rw,user 0 0 (of course, use your uuid at this step and create mount point) Thats it.
