I used python script with Orange pi zero 3 (Armbian_community_24.8.0-trunk.6_Orangepizero3_bookworm_current_6.6.31_minimal.img)
Observation:
1) /dev/ttyS1 is actually Serial 2 as per pin diagram as per Orange Pi Zero 3 - Armbian web page
2) /dev/ttyS2 is actually Serial 5 as per pin diagram as per Orange Pi Zero 3 - Armbian web page
3) even if I set rtscts=True in crateing object ser in above script, there is no output on rts or cts pin.
I am looking forward to have RTS pin remain high during transmission to easily integrate ic for RS485 communication. I was glad that Amrbian for Orange Pi Zero 3 has out of the box RTS CTS pin support which otherwise is a complicated matter for me.
Please guide how to make the serial port work along with RTS pin to remain high during transmission of data.
Regards
Edited by vtech
I also tried adding line "param_uart2_rtscts=1" to "/boot/armbianEnv.txt".
This enabled GPIO Mode ALT2 for UART2_RTS and UART2_CTS.
However, still no voltage changes on RTS or CTS pin when tried to send data over TX.
Looking forward for help. Thanks in advance.
P.S.: WiringPi (https://github.com/orangepi-xunlong/wiringOP.git) does not seem to be working for Orange Pi Zero 3 as it is showing H616 in output of gpio readall command
Regards.
image.thumb.png.61b74347a28a4a742bddad5f6502a974.pngimage.thumb.png.672670c8e82f0308a334eb8041b6efa6.png
Edited by vtech
