CB1 no HDMI output signal
Hello,
perhaps it's a noob question, but I am a noob, sorry 🙂
I had my BTT CB1 on Armbian 24.2.3 Bookworm CLI, with a BTT HDMI 5 display attached. Display was working fine.
Flashed Armbian 24.5.1 Bookworm Minimal (no CLI available on the downloads page) and the display shows absolutely nothing.
Flashed Armbian 24.2.3 back, and it works again.
What am I missing?
armbianmonitor -u file: https://paste.armbian.com/esoboqemot
Have the same experience on a Cubieboard2 ..the Xserver generates output on an Interface called "None-1" instead of HDMI-1-1.
You can switch that with xrandr. but unfortunately xrandr needs an X11-Session with auth cookie to work. I've managed to login blindly
and to fire up xrandr out of the .xsessionrc script but can't be called an solution.
Please check your /var/log/Xorg.0.log if that is the case.
As far as I know you can set the correct video output in the Xserver config file, /etc/X11/xorg.conf.. but you have to set up one first.
Autogenerating one with Xorg --configure fails, so you have to do this by hand.
I've asked in the forum what would be the the intended way to switch the video output before the login  bit got no answer at all.
Regards,
Holm
