[Armbian build PR] - Adding support for the fine3399 board
Description
Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change.
Adding support for the fine3399 board.
Documentation summary for feature / change
Please delete this section if entry to main documentation is not needed.
If documentation entry is predicted, please provide key elements for further implementation into main documentation and set label to "Needs Documentation". You are welcome to open a PR to documentation or you can leave following information for technical writer:
How Has This Been Tested?
The system can boot normally and all other functions work fine, including PCIe support, but the WiFi and Bluetooth functionalities are not available due to the lack of corresponding drivers for AP6236 in the Armbian/firmware.I have submitted the corresponding driver for AP6236 to Armbian/firmware. Please kindly review and accept it.
Checklist:
Please delete options that are not relevant.
View the full article
